2000 chevy z71 issues....please help!!!!
MTeague
I have a 2000 Chevy z71 and in the mornings it fires up fine. Later in the day when i turn the switch over it usually takes 3-4 second before it will start. I have put 4 fuel pumps in the truck in the past 3 1/2 yrs. I have changed the fuel filters. Also while going down the road (It don't do it all of the time) it will start to spit/sputter....almost as if it is not getting any fuel. It will finally catch and go back to running like normal. Has anyone ever had this similar problem???
SunlitComet
OBS Jedi-Do Good
unknown at this time.
Four fuel pump in 4 years is not normal. I suggest you check to make you have the right connector on it and check the continuity of it wiring.
Tricky
Illinois
Well I have had 3 fuel pumps since 2004. I bought the truck new Jan 2000 / Tahoe Limited 5.7. I was just lucky to get a lifetime parts and labor warranty on my fuel pump. But 4 pumps in 4 years is odd. Of course I dealt with the dealer with mine.
Sent from my iPhone 4s using Tapatalk.
Drewphil
