2000Tahoe53V8
- Joined
- Jan 7, 2022
- Posts
- 2
- Reaction score
- 2
Ok, so this stated last Friday night when I started the tahoe. I was still in my drive way when it sputtered and died. Had it on for about 5 min. I started by putting a code reader; 4 codes popped up:
1) U1026 - Loss of class 2 communication with ATC
2) P1637 - Generator L - Terminal Circuit
3) P0463 - Fuel Level Sensor Circuit High Voltage
4) P0108 - Manifold Ablsolute Pressure (MAP) Sensor Circuit High Voltage
I bought the Tahoe used with dash light issues and fuel pump readings not being accurate. This was all I knew from when I purchased it in July 21. I saw the P1637 so I assumed it was the alternator. Volt meter read that the battery was at 12.16. So I puchased a new alternator, installed it and still no start. I was not sure if this Tahoe came with a alternator fuse line. Traced the wire from alternator to battery, could not find one. So I ruled that out. Then I went ahead a purchased new battery, installed it and still no start. It cranks though.
A little help from you guys would be appreciated.
Thanks
Thanks
