2-door hoe's and kon's
rockmax77
Tucson, Az
Did any 2-door hoe's or kon's ever come from the factory with front and rear AC?
Has anyone ever converted rear AC from a 4-door into a 2-door? How hard would it be? Thanks for your thoughts
SunlitComet
OBS Jedi-Do Good
unknown at this time.
front only. there was no room to accommodate the tire jack equipment, tire an rear air all at once and it is not in the order books for the '99 2dr's either only 4dr. it was not ill '98 that rear air was on hoe's burb had them before then. it is not just the rear access you would need there are modifications to the headliner like a different molding and wiring as well.
Gzes
the drifting 2dr
Wichita tx
So in short custom headliner, custom wiring since I doubt itl be plug n play
TallHoe 96 OBS
