2.5"/1.5" Level with 305/60R18
prjeschk
Brighton, CO
I've been around the forums for a while now...don't say a whole lot though. I traded my 07 Yukon Denali on this 07 Suburban LTZ last week.
I went with the Rough County 2.5" Front leveling kit and a Pro Comp 1.5" Coil spacer for the rear. I think it sits just about perfect with that combination, just slightly higher in the rear. Both were very easy to install. I put 305/60R18 Nitto Terra Grapplers on 18x9 MB TKO wheels, offset is 25mm. Rubbing is very minimal, the tire just brushes the front inner fender at full lock. I may do a bit of trimming to eliminate any rubbing in the near future.
Pics before and after level.
Heath McCoppin
Does your LTZ have auto ride / auto level? And if so, have you had any issues with it in the way it rides i.e. wobble / shacking at higher speeds?
Thanks-
01Konvict
Boats n Hoes
Raleigh/SML
Yes it should have it. Not sure if he lengthened the ride height rods or extenders for rear shocks. Need all this to set it up right. That level kit will give you no sway or weird feels
varminpoolteam
