2018 Zoom Zoom Tahoe Build
NYBRD
Vibrant Cold Air Intake
BTR CAM STAGE 2 V2 - 2241023116R1
BTR .550" LIFT BEEHIVE VALVE SPRING SET
BTR VALVE SEAL SET
CHE Trunion Kit
BTR CHROMOLY ONE-PIECE PUSHRODS - 7.850" LONG - 11/32" DIAMETER - .080"
BTR GEN V LT VVT PHASER LIMITER - 4 DEGREES
DOD conversion plugs
AFM disabled
ARP head bolts
ARP header bolts
LS7 Lifters
L86 6.2L Intake manifold Ported
Lengenfelter 95mm TB adapter
LT5 ZR1 95mm Throttle Body
Texas Speed Long tube 1 7/8 headers
CORSA Cat Back Exhaust 3inch COR14859BLK
CTS-V torque Converter GM #24045127
Superior STL010 thermal bypass for the trans
SDPC SD180LT1 - 180 Degree Thermostat
Vacuum pump Delete
Vaccum pump plugs
ICT vaccum pump delete Cover plate
Oil catch can
NGK Ruthenium HX spark plugs .040 gap
DSX fuel coupler
E85 flex fuel sensor #13507129
Helwig front sway bar
Helwig rear sway bar
Rear 2 inch suspension level kit
bilstein 5100 rear shocks
Black Bear Performance tuned
Will get some vid clips posted soon
Have brembos all around sitting in the garage need to paint and mount
buckwild27
I recommend you get this for your vacuum pump delete.
NYBRD
NYBRD
No need for it the way I have things routed
Digs
