16 Escalade led handles
brucebruce45
has anyone figured out how to tie the led handles to come on when the headlights are on?
RB_Trucker
Redondo Beach
I would be interested also, i saw them today on an Escalade in Vegas and would love to have then on my Suburban.
NoLand
I know that pgamboa figured it out for the trucks. I’m not sure he’s on here, but you can find him on GM-trucks.com
RST Dana
EMT/First Responder Firefighter Supporting Member
OH
Does your ride have LED lights behind the inside door handle trim?
RST Dana
OH
You can check the voltage coming to them. Worse case, you my need to add a fused power source for the LED handle feed to connect via a relay to prevent overloading the LED circuit.
cmatt
This. Keep in mind though, if they are tied to the dimmer, the outside lights will dim too.
You could tap into the headlight led strip circuit at the BCM and carry that signal to the doors.
Sent from my iPad using Tapatalk
Docpreston
