I learned from dad and i also took apart the lawn equipment and rebuilt it most of the time.. i killed a few weed eater pull cord recoils the first couple times when i was like 12 or so.. and then built my own gocart motors after blowing them up..
your boy is on his way.. diesel it a different beast from gas.. and 2 strokes..
what was reason for turbo removal??
Yeah, he wants to work on diesels mainly. But I told him that if he wanted to make a career of it that he needed to take auto mechanics and machine shop in high school and then move on to technical school for diesel mechanics. That way when he enters the work force he can come in trained and ready to go to work for any dealer he wants. Work for a dealer for a while to gawin some real world experience and then open a shop of his own later on. So far he is listening.
I actually had a lot goin' on with my truck since the end of november. But in short I replaced the injectors, injector sleeves, glow plugs, strap fuse for the glow plugs, map sensor, cp3 high pressure injection pump, manifolds, custom built super stocker turbo, intake mouthpiece (with a ported version), rebuilt south bend dual disc clutch, slave cylinder, clutch master cylinder, throttle pedal, clutch pedal, rear seal in the tranny, pump rub kit in the transfer case, rebuilt fuel filter housing, a few new fuel lines, all gaskets and seals, new main bearing cap bolts, new oil cooler, new pcv valve, new coolant temp sensor, new fuel rail pressure sensor, new hummer h2 rims wrapped in nitto terra grapplers, and one new battery. And six months before that all started I replaced the brake calipers, and installed drilled and slotted rotors w/ ceramic pads. And of course ALL of my fluids are Amsoil and have been flushed.
But, the bearings came apart in the turbo I put on it and I am having another super stocker built. But I put a used stocker on it so I can run it until the new custom one arrives.
IT has been quite the ride. I told Michelle I couldn't wait for the truck to be done to my satisfaction so I could start on the Yukon....
Below is a link to a good number of the pics we have taken of the process.
http://s278.photobucket.com/albums/kk102/bigdaddydiesel_photos/Truck%20projects/
