12 volt outlet
DRGNRED
I have a 2021 Yukon Denali. I believe the 12volt power outlet was tripped into safe mode. The button on the dash flashes green. Manual says this is because “a protection circuit shut off the power supply” but there is no other info on how to reset or fix the problem. Any help would be greatly appreciated.
NYisles1
Not sure this is it but it looks like there are two circuit breakers on the instrument panel fuse block(right side of the dashboard) for power outlets 1 and 2. I didnt take my panel off to see if it is like a regular breaker switch but you may want to try there and see if you can reset one or both of them.
Robbie3
