09 Z71 bulb type
mtbennett24
Can someone confirm the low beam and fog bulb type foe an 09 Z71? Is it H11?
Thanks
M
mtbennett24
Thanks. Looking at the DDM site and I don't see a 5202 or 9145 bulb type kit for the fogs.
UofMZ71
^ Let us know how it goes and if it melts your housing.
ill let you know tomorrow... ive put them in mine about a month ago (5202). i sure hope they are ok!
M
mtbennett24
Can someone confirm if there is any work to be done regarding the day-time-running lamps on an 09 Z71 if I am installing HIDs in the low beams? From what I can tell the DRLs are a separate bulb altogether but want to make sure there aren't any wiring issues.
Thanks.
tx07tahoe
Houston,Tx
Ya they are seperate on the Tahoes. Make sure you get a relay.
UofMZ71
yes make sure you get a relay/harness. the z71 fogs are 5202 like others and i havent had any melting problems
UofMZ71
i would say no, but ive been wrong alot of times :emotions122: . I just ordered one for my lows, as my fogs havent had a problem yet.
M
mtbennett24
Thanks for the tip. I have seen a couple posts regarding the approach lighting when you unlock your doors. Is there reason to sweat this with HIDs given that the lights could potentially turn on then off after a moment or so if the car is not started soon after?
enigmaspeed27
