08 Denali XL gremlins
snaward
I have a 08 Denali. After driving for extend period, engine idles rough dies when we come to a stop. It does restart after a period of time. So far it has happend 4 times. First time it restarted after a few minutes. After the second it was towed and the dealer replace the throttle body (we were stranded out of town waiting for it to be fixed). After third time (it restarted after a few minutes and we got home) dealer cleaned some connections (said it was related to grounding). Forth time the car did re-start and we were able to get off of the hwy and into a parking lot. We let it cool off for about an hour while we had lunch. The next day we came back home (~200 miles) with no problems. The car is went to the dealer again to see if they could find something - but they did not find anything. But every time, when the motor dies, it has the same symptons of not restaring until it has cooled down some, it sounds like it is not getting fuel, and you hear a "gasping" sound at the end of the attempted start. The car has 62000 miles. Events 1, 2 & 3 happend in July 2011 (+90 deg F). Event 4 happen in Dec 2011 (~70 deg F).
Then yesterday on the way home from out of town the "park assist off" warning kept comming on every time we hit a bump. When I stopped at home, the park assist system appeared to be working just fine.
So is this just a normal example of GM quality or do we have an unfixable car? We love the car's capabilty for people hauling and pulling our camper, but are not sure we can trust it any more.
Does GM have any "super" techs that can trouble shoot car problems when there are no computer error codes?
GM Customer Service
Michigan
Snaward,
If you would like to send me your contact information (name, phone number, address, email address) along with VIN number, mileage and the name of the dealer that you are working with I would like to look into this further for you.
Breanne
GMC Customer Service
S
snaward
Breanne,
Is there a way I can provide you the info you requested in an email vs this public forum? I tried to send GM service a privite message and the system said I was not allowed to since I had not posted enough.
Thanks for your interest in helping.
Steve
cvdaddy
Centennial, CO
I have an '07 Denali XL and it was doing the same thing. It would die at a stoplight after driving for a long time. Sometimes it wouldn't restart for 45 minutes. It seemed to be worse in hot weather. It felt like it was vapor locked. I know it couldn't be, but that's how it acted. I cleaned the throttle body and MAF several times and even replaced the crank sensor. It wasn't throwing any codes, so the dealer had no idea. Finally it started cutting out way worse one day. It stalled at a light and restarted quickly, but cut out while driving a half mile later and I had to coast off the road. Nobody had an answer, so I replaced the fuel pump. I did it my self. The part's about $350. I didn't want to pay another $300 to the dealer, so I dropped the tank myself. Took a couple hours. Knock on wood, it hasn't died since. It's been about 10000. I think there was leak back at the pump when it was hot. I checked the fuel pressure at the rails before replacing the pump and it was reading high and would lose pressure quickly when turned off. With the new pump, it stayed up when turned off.
Hope this helps.
S
snaward
Thanks for the info cvdaddy.
Did you use an OEM fuel pump or another brand?
Maybe I can use your info to get GM to replace the fuel pump while it is still under the powertrain warrenty before we get stranded somewhere.
cvdaddy
Centennial, CO
I used an OEM. My brother works parts at a Chevy dealer, so I paid $300. Also, I remebered over the weekend that the MPG and fuel used data started being off. I drove Denver to Chicago and back and dash said I got 20 mpg. I wish!
S
snaward
Entertainment system off and on
Two new gremlins showed up this weekend.
1. While driving the entertainment system would turn off, then come back on. Afterwards we would notice that system response to the touch screen or the buttons was really slow.
2. I was loaded with 5 passengers and luggage and all I heard was clicking when I tried to start (sound of a dead battery). Luckily on the third try it started and I made it home (~300 miles) with no problems. Except for the radio issue above. This non-start issue happened about year ago just after we got the car, but that time I was jumped and went strait to Autozone for a new battery.
I plan to take it back to the dealer again. Reading other posts, these last two issue maybe related to a bad negative battery cable, aternator, or body control module.
The way it is going maybe by the time the warrenty runs out everything but the body panels will have been replaced and the car will be worth keeping :).
HD4
NJ
interesting. I have an 08' Denali XL bought used with 28000 miles now has 44,000 and never a single issue. had small problems with my previous Suburbans but this has been the best truck i have owned so far.
dlr2416
I have an 08 Denali and have had issues with the AC. After driving for about 30 minutes or so, no air at all would blow out of the vents even though you can hear the blower fan runnin like crazy. Neither cold or hot air would blow out. I went to the local GM service shop, told them about the problem and they keep my Denali for over two weeks. When I finally called them they acted like they didn't even have my car. Two days later they called and sait it was done. I still have the same problem. My Denali has been in twice fo the same problem and its not fixed yet. GO GM Service Team!!!!!
GM Customer Service
Michigan
Dlr2416,
I apologize for this inconvenience. Would you please send me your contact information (Name, phone number, address, email address) along with your VIN number, mileage and the name of the dealer that you are working with? I would like to look into this for you.
Breanne
dlr2416
Breanne
Can I email you. I can't send you a pm because I have not posted enough messages.
S
snaward
Update - I did take my denali to the dealer and this time they did give me a truck to drive, so that helped alot.
The list of problems I gave them this time:
1. The not starting until you wiggle the battery cables
2. The rear hatch would not open (the window would work). After re-starting the hatch would operate as normal
3. The radio turning off and then back on while driving.
4. The radio turns off when you turn off the igition instead of when you open the door.
They maybe all related, I just hope they can find the cause.
S
snaward
The dealer was unable to get any of the problems to happen. So no luck on that end. Now we have a car with a problem that will probably happen at the most inconvient place or time potentially leaving my family stranded somewhere - NOT GOOD.
They also did a fuel pressure check and it checked out fine. So the stalling issue is still not resolved either.
Anybody out there have any ideas I can chase down. I ordered a maintenance manual today so I can at least look at the electrical wiring system.
It seems to me all these recent issues are probably related to a bad or loose ground connection somewhere. Another piece of info, that to me, also points to a ground issue is that when we had the random issues the outside temperature was cool (<40 deg F and dry). The two days the dealer had the car the temperature was warmer and humdid. Per electrical code for hazardous environments, an environment with a humdidity level greater than 60% a person can not build up static charage because the air will dissipate it as quickly as it created.
If we did not like the car so much for its functionality it would be traded by now.
S
snaward
Fixed - maybe
Well we had some good news. The car was acting up again (radio going on-off, misc warnings, etc) while my wife was near the dealer, so I told her to go strait there. Two techs road with her and nothing, but we left it anyway because we had been having the issues for a few days off and on and just hoped that this time the car would mal-function while at the dealer.
Well low and behold the car acted up while at the dealer. He was able to find a bulletin (#PIT4816D) related to symptons and what to check. He found both the positive and negative battery cables voltage drop was out of spec so they replaced both of them.
Now time will tell if it is really fixed, so we are keeping our fingers crossed.
AmazinglySmooth
It makes you wonder, why didn't the dealer search the TSB's the first time? I think GM needs to improve the training of their dealers.
Sheriff
Interesting. Throttle body replaced under warranty? I couldn't get the delaership to do a damn thing on my throttle body. But once I replaced it on my own nickel, everything cleared up overnight.
Based upon my personal experience, I would say NO. They don't seem to do much even if codes are present.
I just bought a new F250 Lariat Super Duty. I went back to Ford. My daughter still likes the Tahoe, so it's more or less hers now. I gave her a business card from my preferred local towing service and told her she will need it.
---------- Post added at 03:54 PM ---------- Previous post was at 03:46 PM ----------
HaHaHa! Ohh, sorry, couldn't help but laugh! Your dealership sounds about as competent as mine. I have to troubleshoot my own problems, tell them what to fix, and pay for parts and labor out of my own pocket. I do remind them that my car is there in case they think they will take it out back and park it for 2 weeks and get by with it.
I had a customer satisfaction call from a girl at my dealership pertaining to my most recent repair. I let her know I was not a happy camper. She was sorry to hear this and said the Service Manager would certaily want to call me and discuss the issue. Did he ever call? NO! Did I ever get a customer satifaction survey in the mail from GM like I normally do? NO!
---------- Post added at 03:55 PM ---------- Previous post was at 03:54 PM ----------
Most of them are independant dealers, GM says they have no control over them. Which is fine, my local dealer just lost a $55,000 sale because of their service department.
AmazinglySmooth
Most of them are independant dealers, GM says they have no control over them. Which is fine, my local dealer just lost a $55,000 sale because of their service department. [/QUOTE]
GM does have control over their training and the incentive programs. GM should be focused on its customers, especially if dealers are hurting its image.
Sheriff
Are you done yet Sheriff? Geez.
Nope. I won't recommend another GM product to anybody. :party52:
---------- Post added at 09:51 PM ---------- Previous post was at 09:46 PM ----------
GM just recorded their highest profit on record this last quarter. After the taxpayers bailed them out of bankruptcy no less. And I personally think they achieved this record profit by asking dealers to cut back on warranty repairs. Although my issues have been few on my Tahoe, I have not been able to get anything done under warranty. They always have an excuse of why warranty should not cover a repair. They won't even pay my $40 tow bill when the throttle stuck open on my Tahoe and had to be towed in for service. And this was after the service department acknowledged the throttle was still stuck the next morning when they started the engine. It appears a GM warranty is not worth the paper it is written on lately IMHO.
HeavyHoe03
