07 Yukon Denali flex fuel conversion
Diegozz12
Hi I’m currently in the process of modding my 6.2 Denali, I’m planning on putting a truck Norris cam kit in it and also considering making it flex fuel.
I’ve read on some forums to swap the fuels injectors and fuel pump from a L9H or a L94 onto my L92 to make it flex fuel, however I have concerns since I’m putting the cam in it that the stock injectors from the L9H or L94 won’t be able to keep up after a tune.
Would the stock injectors be fine or what injectors would you recommend? Or is the flex fuel conversion even worth it?
Geotrash
Dave
Richmond, VA
@iamdub knows the flex fuel system pretty well and might have some insight here. But I believe you'll also need a tune for flex fuel if your ECU can even support it.
B-train
Depending on what your definition of Flex Fuel is: if it's true E85, the truck will run on it (pretty well actually) but you will end up with lean bank 1 and 2 codes because the injectors can't spray enough fuel.
I have found a 30% blend on stock is fine, no codes, but mpg goes down. 20 -25% is a good mix for stock with mpg close to 87 octane fuel. I've been running 89 - 91 recently for many tanks and it only gets slightly better than 87, so not really a cost savings at all.
Lastly, I believe you could find a tuner to adjust the fuel maps to be friendlier to E85 to get a power increase, better mpg than it would get stock, and not have any faults. I recently purchased HP TUNERS to try this for my 2008
rdezs
I think what you're getting at is that the flex fuel injectors can flow a lot more. I believe you also need a different fuel pump in the tank.
I'm assuming in theory, you could go with the flex fuel injectors and the different pump in the tank, along with an aftermarket cam, and with HP tuners you could probably tune it to run quite well..... Again, I'm assuming you're following the quest for more power, and not actually interested in running e85 or whatever they call it?
Towmaster
