07+ Ground Force 3 Inch Rear Drop Spring
S
shundal
NorCal
i did a 2 inch spindle up front with this 3 inch spring out back and the back sat about an inch higher than the front.
I do have the rear measurements on my home computer and can check those this weekend.
ghost
Senior Member
can you post of pic of these coils? do they have any dead coils?
S
shundal
NorCal
Heres a pic of the springs. They measure 15 1/4 inches.
[/URL][/IMG]
Goldelks
Anyone figure out if this would level the truck or make the back sit to low with a stock front end
S
shundal
NorCal
On my 2007 2wd the rear with these springs sat about 35 1/4 from ground to fender lip with 305/35/24. My front with a 2 inch drops sits at 34 1/4, so it should get pretty close to level with the front stock height. Unfortunately i never tried the setup with the front at the stock height.
Goldelks
Wonder how much running 285/45/22 would throw off the measurements?
S
shundal
NorCal
a 305/35/24 tire is 32.4" tall and a 285/45/22 is 32.2" tall. So the 285 is .2" shorter.
---------- Post added at 02:13 PM ---------- Previous post was at 02:10 PM ----------
a one inch spacer would probably be needed to sit perfectly level with the front, which run around $40 shipped.
Escalade2007
