02 vibration
Dustinh
Hey guys and gals just joined. Have an 02 Tahoe L's 4x4 with keys and spacers on 33's and 20x12's. My wife hit a pothole on the interstate and have not been able to get rid the vibration since. Before that I had just changed the idler arm and pitman arm and the tie rod ends. Had the alignment done and tires balanced. After the fact I had to have the alignment done tires rebalanced at rimz one on their road force balancer and I've replaced the passenger front hub assembly. Can someone shed some insight to my problem? Its fine in town but 65+ its bad. Do I need to replace the idler and pitman again? Thanks for your help in advance
treehan77
TYF Fiend
Crestview, FL
i would start by making sure the wheels are balanced still. maybe a weight came off when she hit the pothole. if it was a nasty pothole, the rim could be bent too. i doubt you need to replace the pitman again. start with wheel balancing, then move on to more expensive stuff, alignment etc.
AA1PR
more than likely a bad wheel bearing
the pothole just finished it off for you was all
is the vibration(s) at any one particular speed like say 45-55mph thats usually a tale tell sign to look out for
good luck
southboundchicken
Jacksonville fl.
I would take a hard look at the wheel/tire balance its unlikely the pitman or idler arm would need replacing usually when a truck hits a pot hole like you describe its the wheel/tire/alignment that take the hit
Dustinh
Dustinh
Yea those were the first things I figured as well but I've had the alignment done and wheels balanced the day of the post. I work a lot and haven't been able to get into it deeper. But the vibration starts at 60 and is terrible at 70
griffey_mojo
