Coolant leak ... time for a radiator...
rdezs
The 90 degree ones come off the rear heater core, right behind the right rear tire. The aluminum ones look good. Considering where they live behind the tire, it's a good option. You will need two. Look online, they're readily available for between 15 and $20 each. About 5 or 6 feet of heater hose....5/8", go with a good quality hose. The other fittings and instructions are in the above link I think. Everything's available on Amazon.
petethepug
Michael
SoCal
I found best deal for radiator on Amazon GM Factory store in like new section. It arrived damaged and they only offered refund, not replacement. Ended up paying full price for replacement, keeping it, then returning damaged one to Amazon for full refund. Eat Cake Amazon.
Replaced radiator, added Gates Acc, a/c & pulley kit and H2O pump. Had already replaced heater T’s. Sugg doing coolant resv also. There’s no sensor on gmt900 for low coolant level.
All Denali have heat exchanger in radiator as well as external cooler in front of a/c condenser.
Be careful if access belt or coolant fails, motor overheats. When motor must be shut off at speed to save it (30-45 sec) you lose brakes and steering because it provides 80-90% of energy to control truck. Our 09 Esky blew through red lights exiting a hwy and barely managed a turn 4 lanes wide.
scot moore
scot moore
Ok i now think i understand that guide a little better. it was hard to tell what was going on since i have never laid eyes on this. it looks like GM uses a rigid formed line, and has a short section of rubber 5/8 hose attached to it. in the guide the hose was removed which required those straight adapters that fit on the rigid line and let you connect the hose to it, then the other end gets the 90 degree fittings that attach to the core. I was not understanding at first why some pics were a 90 degree, and some were the straight ones, and it looked like it fastened it 2 places each. i see now the shorter rubber hose was also replaced.
rdezs
The reason for modifying a new section of heater hose to the factory piping for the rear heater core.... Is that the only official replacement is to replace the piping from the engine bay that comes with the new hose crimped on the end. And it usually comes in two pieces coiled up that you have to straighten, and connect them with a supply compression fitting. Sounds like a real PITA, and if I remember right it comes with the metal ac lines as well. Likely a necessity for some vehicles in the rust belt though....
Charlie21ny
