L87 Failure - Taking formal action
apex944
I briefly outlined my failure scenario in this post. Here is my plan to request that GMC deal with the situation BEFORE I have a safety issue at speed.
My Argument:
“GM’s known defective L87 engine is continuing to generate objective wear evidence after the recall remedy, and GM’s own recall exists because the defect can cause loss of propulsion. I want a documented warranty decision now, not after a highway failure.”
My Request:
“This vehicle continues to show abnormal internal engine wear metals after the L87 recall remedy/Pico test. I am requesting diagnosis for ongoing crankshaft, connecting rod, and bearing deterioration under recall 25V-274, Special Coverage N252494003, and the GM powertrain warranty. Please open a repair order and attach my oil analysis reports, and opened filter media photos.”
My Plan:
1. Get a formal repair order. The RO should mention excessive wear metals, L87 recall, suspected bearing/crank/rod wear, and my request for engine replacement or further diagnosis.
2. Ask Service Manager to open a GM TAC case / field engineer review.
A dealer can't authorize preemptive replacement, but GM technical assistance can.
3. Ask them to cut open and inspect the current oil filter, document debris, and run any GM-approved diagnostics beyond Pico. My oil reports become stronger if paired with physical filter evidence.
4. Will escalate to GM Customer Assistance and ask for a case number, not just a service appointment. GM’s own warranty/lemon-law help page tells customers with ongoing warranty or repair problems to contact GM directly.
5. Will file an NHTSA complaint.
NHTSA has already opened Recall Query RQ26001 specifically because it received complaints of L87 engine failures after the recall remedy was completed, and it is assessing whether GM’s remedy is adequate.
6. I will talk to a lemon-law/warranty attorney before accepting any GM settlement or trade-assist offer. My case is better than a normal complaint because GM has already acknowledged the L87 defect, NHTSA has an open post-remedy inquiry, and I have serial oil-analysis data and physical wear evidence.
PS - I suggest everyone with a 6.2L get a used oil analysis, have an indy cut open your filter, photograph it and file the same requests as outlined above. Together we are stronger.
2024 White Tahoe
Let us know how your dealer service experience goes.
When will you be taking your vehicle to a dealer for the action you listed?
all I can tell you is GM's pockets are much deeper than your's. good luck, perhaps join one of the class action lawsuits and see how it plays out. Spidey sense say's not good
your probably better off grinding off some metal and throwing it in the oil fill tube and then go drive it till it sh*ts the bed. :secret:
Marky Dissod
My Plan:
2. Ask Service Manager to open a GM TAC case / field engineer review. A dealer can't authorize preemptive replacement, but GM technical assistance can.
I very strongly suggest removing the oilpan drain plug and sticking a flexyscope in there.
IF ANY SWARF IS VISIBLE, that's even better for your case.
ZKWBQD
My Argument:
My Request:
My Plan:
"indy" ??
TrueAt1stLight
Minneapolis
…and I love it! Tag to hear of eventual outcome.
PPK_
Oklahoma City
looks like the test showed aluminum and iron... could be a main or rod and a crank.
i do not like the pico test... at 2,000 rpm.. lots of oil pressure. this would reduce any knock that this might find. it is totally bogus. you really need to run the engine up and down in rpm looking for noise.... so like the department of transportation to agree to something that is not going to find anything.
if i were you... i would show my evidence of high iron.. and expect the dealer to mic each rod and crank. you want a report on each one.. 5 mains and 8 rods.
that is what i would do if you brought it to me. logical.
this not expecting an engine.. this is what is needed to get one. an inspection of the crank... this is further than a pico test.. and you demand that they do it...
Pete
ReaperHWK
If I were to you I’d just buy a 100k Knapp warranty. Thats what I will do if my oil analysis comes back suspect on my 2026 6.2.
I have 11k on mine and sending in the oil soon, had about 6k miles on this oil.
What oil were you using? Penzoil ultra plat is probably one of the best I’d switch to that and see if anything changes.
2024 White Tahoe
My Argument:
My Request:
My Plan:
Have you taken the vehicle to the dealer yet?
1948Buickroadie
