LSCALADE
I did a 2” rear drop and I love how it turned out.
Jeff_
Scottsdale, AZ & N. Idaho
One of my low beam headlights went out. VLED LEDs lasted 4 years. Not too upset, bought another set because if one went out, the other one probably isn't far behind.
Should be here this week, luckily fairly quick to swap out.
When I find bulbs I like I buy extra's to keep on hand just in case, and because sometimes whoever made them falls off the end of the earth and you can't get same ones anymore.
as is the case with some HID's I bought for the silverado in 2019, now I am on my spare set and the only place to get the same bulbs is from Italy for 3x the price I paid.
or buy 10 sets from alibaba..... :shrug:
LSCALADE
My good buddy has a rare Escalade I believe 2020 and its got the full CALLAWAY package. Quite the beast of a truck. This thing went to Callaway with several miles on the odometer before it was ever owned by a single person. Its crazy rare machine. SC560 kit is super nice but no one ever has any parts for them, everything has to be bought through Callaway I guess.
Kobot
Yesterday I swapped the transmission pan to PPE, changed the filter and added fresh fluid. Another all day job. Doing this on jack stands really slows things down but it’s doable.
LSCALADE
I got RAM wheels 20" these are probably going to be the ones I keep on it forever since they fit perfect, are light weight compared to the GM units and look the best with a wicked deep concave look. Just need to get some badges.
And as a bonus they clear the huge 16" performance brakes with tons of clearance left.
k_arnold72
Just found out that you can now make changes to the T87a with hp tuners as well. It cost another 4 credits, but it appears to be unlocked. I was able to read the oem tcm file, make changes, and write to my stock tcm that hadn't previously been unlocked.
Autosync is primarily for BCM tuning, for TCM tuning you'd need something like a Diablosport Intune (which I also have). I've only used the in-tuner adjustments but you can have custom tunes created
gat0r
DFW
curious, what is there to buy from Callaway?
i had a '15 burb Callaway
i had their sway bars & BBK too... i didnt buy pads from them, just went straight to StopTech. (plus it was cheaper for same pads)
& air filter wasnt proprietary
that looks like Brembo front kit
LSCALADE
well comparing to mine, its got the Chevy Performance 6 piston brake kid with some fancy decals, same exact kit on my Suburban, sway bars are red and bigger, and I looked on their web site but I am unable to find any parts from them for sale not even on ebay.
gat0r
DFW
ah, i get your statement now.
most of the parts used to be on their site.
but overall, was only visible on order form.
in 2015:
Sport Pedal Package $390
Sway Bar Package {w/ end links & upgraded bushings} $830 , (38mm ft / 32mm rr) *
* = not sure who, but is either Hotchkis or Eibach
guess they use Chevy Brembo kit now
used to be Proprietary StopTech kit
trailblazer
I bought this Esky with known gremlins. Well, this had the notorious rear bumper, wiring-harness-melted-by-the-tailpipe syndrome at one point. Whoever repaired it used non-weathertight crimps and they were all corroded and I was getting a ton of warning lights from those. I did not want to drop the money on the factory connectors as they are rather expensive even for my wholesaler. I opted to install Delphi GT 150 series 12 pin connectors. My vehicle config only uses 17 of the 23 wires that are noted in the wiring diagrams. Took me three hours as this is very tedious work - especially when lying on your back.
AZPatriot1963
