Purchased our 2021 Yukon SLT 5.3L in November 2024 with around 62,984 miles on it.
It now has 69,668 miles. So I've only 6,684 miles on it. But the service records were very clean and the truck hasn't had any issues.
First mod I did was the Range RA007 module.
I've replaced all fluids and the battery. I need to do coolant tho here sometime later this year.
Been a good vehicle for us, knock on wood haven not had any major issues. Doesn't burn any oil. I ran the dealer oil for a few months then switched to Amsoil Signature 0W20. I'll be using that for the duration on this vehicle.
Minor issues:
1. When I purchased the vehicle, I noticed the "rear diff groaning" issue, but after draining the diff fluid and installing some better LSD additives, it has bee quiet.
2. The driver seat lumbar does not work. Not sure what's going on with it, I've replaced the switch still nothing. Need to dig into it later.
3. Several of the headliner clips come loose around the pano-sunroof. Common issue, there was an updated clip released to provide better retention. I ordered them and have them on hand, just need to find time to drop the headliner to replace the clips.
4. About 1 week after purchasing, the battery died. It was the original battery. Threw a bunch of crazy lights on the dash. Replaced it and everything went back to normal, been fine every since.
