Fifth generation (2021+) Total Mileage?
cjlewis
Curious to know what people have total mileage wise on their 5th gen Tahoe / Yukon’s? Obviously, there’s lots of talk about the engine issues, lifers…etc.; however statistically that is small (not insignificant though).
2023 Yukon Denali Ult
6.2L (second engine / replaced @ 16,000 miles)
Total miles now 88K
PPK_
Oklahoma City
2024 - 11800 miles. New drivers side rear half shaft... otherwise ok. now i do have a carbyte and a oil trap on the intake..
Kehoelaw1989
2022 Tahoe RST- 69k
Super comfortable and reliable. Love this ride!
JKeller
2021 Tahoe HC with the 6.2L. 138,000 miles. I tow approx. 5k miles per year, mainly highway. Knock on wood, only failure I've had was the water pump at roughly 40K miles, which was fixed under warranty. I also had the rear diff groan but that went away once I added the additives with the GM fluid. I've run Amsoil 5W-30 signature series every 15k miles in it since I bought it with 26K miles.
Padraig
Army
2023 Suburban, 44,000 miles. Absolutely perfect. Normal maintenance is all that has been done to it. Has Suburbans and Yukons since the 90s...this one is the best.
Padraig
coder
24 Yukon SLT, 5.3L with 35,000 miles. Only thing that needed replacing was the passenger side cv joint early on as it was leaking grease on inside part of rim. Other than that, so far just 5k oil changes.
martinajm
2022 Yukon XL w/ 3.0. Actually right at 50 months of ownership. Just hit 100K miles today.
Warranty repairs include the coolant control valve (about 75K), the "groaning" rear diff (about 90K), Oil Pan leak and front crankshaft seal (99.6K).
I did have to replace an Onstar module recently, but that has been my only out of pocket repair expense due to mfg defect.
Blueinterceptor
21 Tahoe 40k. Traded in
23 Tahoe 20k traded in
25 Tahoe 7k
26 suburban 7k
No real issues with any of them
23’s were traded in because of fear of the 6.2 L issue, not because they had issues.
ReaperHWK
2026 RST w/ 6.2L. 6200 miles, about to do its THIRD oil change!
RST Dana
OH
2021 HC 115k with catch can
New pistons and rings at 59k for oil consumption
Trans had a clutch bearing whine at 42k
All repaired under warranty.
6.2 for the smiles!
esanthief
22 sub 67k miles. High pressure fuel inject replaced by warranty. It was caused by a fail fuel pump 3 months ago and I had to pay by myself
jerry455
2021 Suburban HC, about to turn 100,000 miles, 99,871. Replaced transmission at 80,000 miles. Passed PICO, so hopefully. I bought it used 2 years ago with 70,000 miles. I have had a Range module for about a year and a half. I installed a large Walker Dynomax muffler 17789, 3" in, out and through. Slightly louder but nice.
fondupot
South Carolina
Purchased our 2021 Yukon SLT 5.3L in November 2024 with around 62,984 miles on it.
It now has 69,668 miles. So I've only 6,684 miles on it. But the service records were very clean and the truck hasn't had any issues.
First mod I did was the Range RA007 module.
I've replaced all fluids and the battery. I need to do coolant tho here sometime later this year.
Been a good vehicle for us, knock on wood haven not had any major issues. Doesn't burn any oil. I ran the dealer oil for a few months then switched to Amsoil Signature 0W20. I'll be using that for the duration on this vehicle.
Minor issues:
1. When I purchased the vehicle, I noticed the "rear diff groaning" issue, but after draining the diff fluid and installing some better LSD additives, it has bee quiet.
2. The driver seat lumbar does not work. Not sure what's going on with it, I've replaced the switch still nothing. Need to dig into it later.
3. Several of the headliner clips come loose around the pano-sunroof. Common issue, there was an updated clip released to provide better retention. I ordered them and have them on hand, just need to find time to drop the headliner to replace the clips.
4. About 1 week after purchasing, the battery died. It was the original battery. Threw a bunch of crazy lights on the dash. Replaced it and everything went back to normal, been fine every since.
pro-v eddie
2021 Yukon Denali 6.2 39000
No mechanical issues with the drive train.
New Michelin tires at 26340. Factory tires wore terribly. Followed scheduled oil change and tire rotations. Brake fluid exchange at 36158. Engine air filter and cabin air filter changed per schedule. This truck behaves well!
ProfeZZor X
High Country
2022 Yukon AT4 - 79K
General Maintenance, no issues.
Johnny Fr
'25 Tahoe HC coming up on 9 months daily driven and 7k miles. No issues except the lack of heat on pass side which was fixed. Oh the chrome did flake off the driver door handle no biggie just get Band Aids when on sale at Costco :)
Johnny Fr
I concluded this makes sense! I figured we'll do every 5k at the dealer to get the tire rotation as well and to document, but that I'd DIY one in-between at 2500 (it's so easy). When ours reaches 7,500, I'll do the 4th oil change (first was DIY at 9xx), and at 10k the dealer the 5th....I'm going to see if our dealer who charges $95 (it's not bad compared to near my house $140), will match a competitor coupon at $79.95 (I actually don't trust dealers who have a price $60 less than the other dealer next door, could be they don't do the work)
tagexpcom
2021 Yukon Denali 6.2 at 71K miles, 1st 50K was Hertz rental, last 20K (I've owned since Aug 2023) towing 5500lb trailer. Love the rig!
1948Buickroadie
