rsparrish82
- Joined
- Mar 2, 2026
- Posts
- 19
- Reaction score
- 15
Hello all..
As I go farther down the spiral with my 2003 Yukon Denali, I have discovered a few things pertaining to the HVAC system. Im just looking for further validation before I decide to either dig in, or send it to a shop.
I performed the HVAC reset, which actually fixed a few things, but one it did not was the passenger side front. with heat or AC set to max for both, the passenger side front vents only blow mediocre heat, and mediocre fan, while the drivers side and floor (on both sides) blows super hot or cold respectively. Based on what ive been able to research, this is caused by the blend door actuator in the center of the dash. I have run through enough settings on the climate controls to verify that the passenger side front facing vents are the only ones affected.
As for the rear... i strongly believe the hot/cold blend actuator is bad. All other functions (fan speed/ vent selector) work fine, just no heat... not super cold, but luke warm at best. I realize this could be the heater core back there, but there are no leaks that I can see. I am going to do further testing with this one, as i want to remove the rear panel and have someone operate the controls while i watch the actuator move (or lack of).
I am certainly not excited about the front actuator being bad since i will have to take the dash out to replace it. Which is why I am asking here. I know there are a lot of threads on the HVAC systems here, and this is actually where i got most of my info. I just wanted to ask the great collective here what you all think.
Thanks for your input!
