Can you help me with OBDII code: P0430 ?
Beeker702
Buffalo ny
They refreshed the computer, they were finally able to inspect the truck and it passed but the damn light came on Thursday night with the same code
j91z28d1
this isn't exactly the same, since his was a rear o2 code with denso. but just for info.
Beeker702
Buffalo ny
They flashed the module and was able to finally inspect and pass inspection but the damn light came back on Thursday night still with the 430 code. I tried some things with my scan tool since I updated some of the software on it. We shall see if what I did worked or not in a few days
Beeker702
Buffalo ny
Check your fuel trims. If you can’t then disconnect the two hoses that goes from valve covers to the air intake. Clear the code and drive to see if it comes on, if it doesn’t then it’s your high pressure fuel pump located under the intake
Tahoer2008
