I had the GM Performance Exhaust installed
Sgt1411
Great review Thanks...I'm building my 25 RST and was on the fence about the LPO Performance Exhaust Upgrade but your results are exactly the same as my expectations.
Its around $2200 for the Exhaust and Cold Air Intake Performance Package if you order it from factory, what is it from GM Parts?
Sean Michael
Sean Michael
DFW
If the GM exhaust and CAI was an available option from the factory for $2,200 when I bought mine, I would've done it in a heartbeat. The exhaust alone is listed at ~$3,300 on GM's site when done after the fact, but I paid around $2,700 because they were running a 20% off sale through year-end when I ordered. GM doesn't even offer the CAI after the fact at all anymore, so if you want that, you have to order it equipped from the factory. I'm looking into third-party options at the moment.
If you are interested in performance, the best way to achieve that is opting for the 6.2L, which was a "must have" of mine when buying my RST. A stock 6.2L will blow the doors off a 5.3L all day long even if the 5.3L is upgraded with exhaust and CAI. You didn't mention which engine you're considering, but engine choice is the biggest bang for the buck if someone was debating between the 6.2L as it comes or the 5.3L with exhaust & CAI. The 6.2L goes hard, prioritize that, and any exhaust & CAI will be gravy on top.
Sgt1411
Your absolutely correct about the 6.2L and I did spec that engine out. Its good to hear a second opinion on the package being good bang for the buck, especially if you cant get the CAI as a stand alone GM Performance Part later after delivery. I will ensure both are ordered as I like the fact if its ordered from the factory its covered by the factory warranty.
23Seven
I went with a Flowmaster Super 40 and keep it in L9. I couldn’t be happier for a $400 job from my local exhaust shop.
Mine is 2024 Tahoe z71 6.2L that came with dual (dual tip) tailpipes.
OP, That’s great that you are happy with your setup, that’s really all that matters.
Sgt1411
After driving my 25 High Country for the past few weeks I can confirm you were bang on about the 6.2L What a beautiful power plant, the way its geared with the 10 speed transmission is so well done. The 25 High Country has the factory dual exhaust and every morning that start up exhaust sound makes it worth the purchase right there. I wish I could buy the OEM Cold Air Intake they offer with the clear top on it. Other then ordering it from the factory I cant see it anywhere on any GM Performance site.
Sean Michael
Sean Michael
DFW
I enjoyed my 6.2L with the performance exhaust that I made this post about. However, the power it provided was a gateway drug so to speak, I went for even more performance and traded it on a 2025 Cadillac CT5-V last week. I'll miss the 6.2L rumble and copius interior space, but the V Series Cadillac that replaced it is an absolute blast to drive. 0-60 in 4.6 seconds, adjustable suspension with track mode and launch control, manual mode paddle shifters, Brembo brakes, active exhaust, and drives like it's on rails. Performance is addicting.
Sgt1411
You can get both things you want....but it is a $150,000 Escalade V.......:)
iamlegion
That or Hennessy or Lingenfelter both have 650hp+ packages now that have an OK warranty and you could still probably pick up a used Blackwing for under $150k.
66 Galaxie
Calloway also has a supercharger package or you could buy the whipple charger kit and DIY
mechman22
