Hi y’all! I have a 2012 Gmc Yukon xl … does anyone! Know where the remote key entry antenna is located?
Does anyone know of a scan tool that will program my new rke and my key fobs to my Yukon? Or do I have to take it to the dealership? Thanks
you can program modules yourself but it takes some investing in tools to do so and you need a pc or laptop or windows tablet. gm charges $45 for 2 years of programming (per vin number). used to be you could grab a mdi clone, but apparently some have been produced with malware and you can get locked out of your programming account. so a 3rd party adapter is probably your best option. Those typically run $300 and up
mikez71
@j91z28d1 knows of a good cheap device (OBDx?).. (but you still need a computer and subscription to GM's programming website.)
The AutoSync (btdieselworks.com) will let you program key fobs. (you can just learn new ones without relearning all remotes with this particular device)
It's a great all around product that lets you read DTC's and see other sensor data in the factory cluster display.
petethepug
Michael
SoCal
Get the AutoSync. On 12-14 Denali it turns on back up cam during turn signal and or manually at anytime, any speed. He also just introduced Video/Navi/Phone screen use while in motion software.
Best of all it’s not vehicle specific so it can be resold if you sell the truck.
Explained further…
Autosync…
Rwkluge1
It’s weird .. remote door locks and remote start will not work . The the tire monitor light is also on.. I did see somewhere it’s all tight together. I have had the the key fobs checked and both are good ! Lost
I’m not the answer guy but
Mike
I have looked all over the net and no answer
I’m not the answers guy but I thought it was a part of the front passenger side window control. I’d start there, as ive found this to be true on similar GM models. Hope this helps
Mike
hey Mike I’m not the answer guy but I believe it’s all part of the front passenger side window/control on
Gearz
The dealer should only charge an hour to program everything to the truck as long as the part is installed just leave the pillar panel off in case they need to check the P/N. I just had a dealer program a new BCM and both key fobs for $180.00 that was a hours labor in my area but not all dealers will do that so call first, some said I would have to buy the BCM from them which was $300 more than I paid so I kept looking.
Dirt71
I think what you’re looking for is a PIP sensor. It’s on the back floor, under the carpet, right past the hump. Under the 3rd row seat. Mine has came unplugged several times. It’s about 4”X 1” it will (should be sitting on a stud
Dirt71
I think what you’re looking for is a PIP sensor. It’s on the back floor, under the carpet right past the hump. Under the 3rd row seat. Mine has came unplugged several times. It’s about 4”X 1” it will (should be sitting on a stud
My bad, I was thinking of the K2 model
pistolpetem9
