3" Ready Lift Leveling Kit on a 2022 GMC Yukon AT4
WacoYukon
Here are pics with 275/65/20s Nitto Recon Grapplers before I have it taken off and a 1" or 1.5" leveling kit installed. This kit feels like it lifts it too much and creates too much wheelwell gap if that makes sense. A 34" tire is the tallest without rubbing on a stock wheel FYI.
WacoYukon
WacoYukon
More pics
WacoYukon
WacoYukon
last two pics, stock tires
STORMIN08
i think it looks good at that height, but the tire selection it self can have a huge effect on appearance. i generally try to find a good tread for all purposes (looks, ride and noise), but tend to favor the most aggressive sidewall appearance.
that helps give the aggressive looks and makes the height look more appropriate.
tenminutes
Agreed to the comment above. Some Nitto Recons with the dagger sidewalls out would change the look a ton. Though I really like these AT4 wheels, on mine I had to bite the bullet on the Vossen 6 lugs bc I'd concluded that to make these stockers fit with the 35" tire on this lift I would need spacers. Which I won't run on a $95K family car (I had to overpay here in Texas for a white AT4 6.2 bc I'm a sucker).
These Yukons seem to need a 35" tire to be proportioned correctly. I'll do a full thread mid July when I'm all finished.
ProfeZZor X
High Country
It didn't take long for me to get use to the new ride height when I installed my 3" Ready Lift kit. In fact, I like it raised a little higher now, than I did when it was at the stock height. With tires and wheels, mine reaches a height of 6'6".
guarmanm
