Parking pawl replacement 6l80e
Has anyone ever replaced the parking pawl on am 6l80e? I have no park.
I have not but have looked up how to do it and posted instructions from my shop manual on here before.
If memory serves, the valve body has to come out and maybe the tailshaft as well. Sometimes people bend them while doing transmission work and they can be bent back to working again.
Did you first check to see if it was the cable or connection on the side of the transmission?
W
Warriorpluto
No I didn't check. I'm assuming the worst right now. I'll get under the truck later and verify that it's in the correct position. Do you have a link on your post about it?
No link, it wasn't that detailed. To do the work you ought to purchase a subscription to the shop manual from places like Mitchell or AllDataDIY.
MWD_CTSV
As @swathdiver said, the actuator rod is probably damaged and can be removed/replaced without pulling the trans, but you may to need to pull the valve body to get access to one of the roll pins.
There was an update around 2008 to a stronger rod, so I would upgrade if necessary. The rivet on the end also gets damaged from being forced into park, so even with the updated rod you made need to replace it if it is damaged. But once you drop the pan it is visible.
W
Warriorpluto
This rivet can be replaced easily as well?
MWD_CTSV
I have the detent spring removed here for visibility, so you can see the parking pawl engagement rod attached to the shift lever. You need remove the valve body, so that you can access the roll pins on the shifter shaft. One pin holds the shaft in the case and the other holds the internal arm to the shaft. Technically the 'pawl' itself should be fine, but the rod from the arm back to the pawl engagement is what is likely bad.
Jake 2015 GMC Yuk
