Need video or link
Amp653
Does anyone have a link or pictures of how to remove the two storage areas in rear hatch. I want to tighten up my rubber mat and can seem to do it any other way.
Both sides of the cargo area. Those pieces that house the jack etc
just search for how to replace rear ac blend door, that will show you how to access the rear panels, it's rather easy you just have to pop the trim pieces off along the bottom where the hatch latch is and the one across the headliner at the top, then use a small tool to get the trim piece open to remove a couple bolts on the rear pillars and then it pretty much pops off from there.
BWASTEEZE
