Need help with Arnott struts/shocks on 07 LTZ
Slow5.0
Missouri
I have 07 LTZ 4wd with 125k miles. Front struts and rear shocks need to be replaced together with new air compressor since original is very noisy. I have been researching Arnott set up but i coundt figure oit what to buy from them for rear. They have cheapper passive shocks for $151.35 or new better shocks for $237.55. And i dont want reman shocks from them since they only replaced air bag. Yesterday i call them and guy told told me difference is that cheapper shock need some kinda box to be zip tie for resistor and more expensive one is plug and play. I dont think thats difference and guy just want me to sell cheapper one for some reason. So what better rear shok from them and way
Also fo the front should i go with premium stuts $220.94 or value struts for $179
Thanks
Slow5.0
Slow5.0
Missouri
I just spoke again with cust service and this tie it was some lady. Didnt catch her name but boy he know her stuff. So pretty much valu struts/shocks are lower grade quality more like softer ride than premium one
Other thing about Arnott warranty is life time if you bubdrombthem. If you buy from 3rd party than warranty will be whatever 3rd party will offer. So keep that in mind
Graystone_OG
NYC
I ordered my back shocks from eBay from the seller AM Autoparts. And a Dorman compressor from Amazon part #949-001.
Look for ARNOTT Air Shocks Rear Left LH & Right RH Pair Set for Chevy GMC Cadillac. They're $378 right for the back pair.
Same seller has the front shocks pair for $387.
Slow5.0
Slow5.0
Missouri
I was goingbto order from am autoparts than i found out warranty will be from am autoparts only since arnott wont cover it since am autoparts os resealler. So i found discount code gmsave10 and save $70 on rear shocks and air compressor all from arnott. It was $30 difference at the end and i got it directly from arnott. Should be at my door step tmrw morning.
Thanks any way
Slow5.0
Slow5.0
Missouri
Arnott rear shocks 2700 and air compressor 2793 show up yesterday. Will be installing them today
Graystone_OG
NYC
Nice. Install is very easy for the back. GL
Sent from my Nexus 6P using Tapatalk
Slow5.0
Slow5.0
Missouri
Its not first time im dopping shocks/springs. I used to swap strut/shocks and spring on 94 Mustang GT in parking lot of race track between runs. Heck i even swap turbos and egr valves on the sholder on interstate on my 18 wheeler
Graystone_OG
NYC
So basically installing with one hand tied behind your back hehe
Slow5.0
Slow5.0
Missouri
Finished installing Arnott/Bilstein shocks # AS-2700 and Arnott air compressor # P-2793 is evening. First impressions. Its much better than my original 120k rear shocks, but its not road race car much better and wont win any races, i can say it probably with pair if not little better than new GM shocks. Also air compressor is quiter than my old rusted compressor. So $213 each shock and $209 air compressor i say its good deal. BTW thats with 10% off if you use discount code GMSAVE10. If you gonna order online there wont be discount on compressor, but if you order over the phone and tell them to use discout code, you will get 10% discount on compressor. So there you go
Wake
Stafford, VA
Glad you didn't go for the passive shocks, I tried them on my 05 and hated them.
I never considered the Arnott reman before because they only replace the airbag and I figured the shock would be shot. I found out recently the rear shocks are built pretty darn good. I picked up an 03 EXT a couple weeks ago because I need a pickup truck and started working on it. I'm rebuilding the suspension and steering on this truck because of it's mileage, 180K. The rear shocks both had torn air bladders and the pump was seized from running constantly. I had the rears from my old 05 with 83K miles so I swapped them out and was surprised at outside of the bad airbags the shocks themselves were in decent shape. They had the same compression and rebound resistance from what I can tell as new shocks, I assume because the airbags take most of the abuse. The previous owner took good care of the truck, cosmetically and powertrain wise, but he told me he never did any suspension work on the truck which he purchased at 100K miles.
The fronts though seem to take more abuse because of the weight of the engine and the fact that they don't have airbags to save them from some of the abuse a shock takes. Those I'll replace on any auto-ride truck I buy. The backs though, I'll hold off replacing those in the future unless they have leaking or torn airbags.
I saved a little money replacing the pump. The pump in my 07 was noisy but working so I replaced it and never got around to throwing it out, so I took the old pump from the 07 and spliced in the 03's wiring harness and had a working pump for free. I don't know why GM changed the harness plug on the 07 models because everything else is the same as the earlier trucks.
Slow5.0
Slow5.0
Missouri
Arnott pump came with two harness. One with square and one with round connector. My 07 use square so maybe round one is for 00-06
Wake
Stafford, VA
That's what it is. My 05 and 03 use the round connector and the 07 has a rectangular shaped one. Everything else is the same and works the same.
Candielaine
