2015 Yukon HID Conversion from The Retrofit Source
k5blazerkeith
Not meaning to dredge up an old thread (that has old title), but just adding an update to my earlier post. I bought the HID kit from KBCARSTUFF over a month ago and it works perfect...not one complaint. I bought the Philips 4300 upgrade bulbs, rest of kit is the standard XenonDepot kit, with the Canbus adapters (they act as your capacitors also - confirmed with KBCARSTUFF tech guy). I was afraid to write this (Murphy's Law says that now I'll have an issue!), but given that everything has worked perfectly, I am hopeful they will keep working great for long time. If anything fails I'll come back...
toi
could you put a link here for which kit you are mentioning in this post please.
thank you
toi
RikMN
Quick question did any of you who upgraded need to realign the projectors or notice you get flashed by oncoming traffic?
pro510
Those who used the extreme HID 35w, did you use the relay? I haven't installed yet but plugged one in without the relay and it worked OK.
What have people done about the auto lights - anyone managed to get the DRL harness from gen5diy to work with HID?
Thanks
Sent from my SM-G900P using Tapatalk
LGSONE
RikMN, I've always checked after putting in HID's, measured and adjusted as needed. With these truck sitting up a bit higher I try to be respectful of others... We have all seen the dumbass who didn't and it is annoying AND a waste of the investment if the light isn't hitting the road where it is needed.
LGSONE
toi
Did you use the coupon code?
i havent bought it yet.
this kit in the link doesnt mention anything like canbus and such.i am not even sure if i need those things yet.
but this might be the kit to buy.
we will see
pro510
we will see
Xenondepot.com is the same company and has the canbus option shown.
  • Like
Reactions: toi
toi
just purchased thier extreme h11 hid kit with canbus and philips bulb upgrade wish me luck :)
how are yours holding up so far?
thanks
pro510
I ended up ripping them out. After a couple of weeks one of the ballasts went. When I got the replacement and installed them all in again, the other one started flickering. At that point I couldn't be bothered with the hassle so just took them out. I was using the relays as well as the canbus.
I later went with LED, but they just flickered too. So I am back to halogen bulbs (Silverstar).
Good luck.
toi
Good luck.
Well thanks man , appreciate the fast answer, just went ahead cancelled my order on that note.
Anyonelse with succesfull results wanna chime in?
vishnu619
My extreme kit is over a year old and going strong.
Sent from my LG-H811 using Tapatalk
toi
Well thats a bit of good news, could you let us know your setup part by part please?
Thank you
vishnu619
Xtreme kit, canbus, phillips bulbs. You can use code 4thcivic to get $50 off plus canbus for free. That code is old so if it does not work you may have to search for a new one.
vishnu619
Areola Borealis
4 month update:
After many night time driving hours including a trip from TX to NY and back, this kit is still doing extremely well for me. No flickering or failures to turn on. I'm using the philips bulbs without the canbus. I'm actually using two separate relay harnesses though which allowed me to independently wire the bulbs and ballasts from each other. After I got the mess of wires properly managed and hidden, I siliconed the hell out everything.
Final thoughts so far:
Extremely impressed. I had major doubts after I ordered the kit and found this thread. Decided to try them anyway and have had zero issues. Not to mention they're extremely bright.
  • Like
Reactions: toi
Durobans
