To start things of this is gonna be a bit of a slow build as i haven't had the truck for too long,but I needed to take care of some things before all the mods start.
When i got the truck it had 22's that i had to take off got myself some 17's off a 2011 silverado and plasti dipped them.i noticed with them side by side there wasn't much difference in their height.
Now to more important things the dreaded rusting brake lines -_- I used acdelco pre bent kit. They were not too bad but it was just such a pain to get them in.best advise for this kit,
label your new lines,remove the driver side front and rear wheel splash guard gives you so much more room, dran your brake fluid before you start undoing lines
how bad the old ones were
Speed bleeder and pressure bleeding are your friend!
FYI the front and rear bleeder screw are not the same despite what amazon says or at least for my truck they are different
Diffs and t-case
my original cover was rusting out mind as well swap it out
but chrome would have looked out of place guess there was only one thing to do .... black it out
Diffs and t-case
