LED flasher
95escahoe
I have LED tails on my 95 Tahoe, would like to upgrade the bulbs in the front turn signals but I think I need to upgrade the flasher? Does anyone know what one I need? Looked around didn't find much
Crispy
Slate Belt, PA
Just want to verify that it is required to in fact change both hazard and turn flashers. Reason I ask is that my previous GM's only required a turn signal flasher. I believe it was due to the hazard circuit not being resistance dependent.
95escahoe
95escahoe
Pretty sure the Vortec ones only need one and its the TBI trucks that need two without the hazard one they wouldnt work when u pushed the hazard button
Crispy
Slate Belt, PA
I get that but in my current Trans Am and my old 95 for example I installed LEDs and just changed the turn signal flasher. Obviously different vehicle but GM has a habit of doing things as few a times as possible. The Vortec ones do only need one.
SunlitComet
OBS Jedi-Do Good
unknown at this time.
the hazard flasher on the trans am maybe already solid state type. another note that even if leds the hazard flasher is seeing twice the load so it may think it is is a standard turn with working regular bulbs and functions normally. put the leds in and find out. change it if needed.
dizhai
