American Racing Torque Thrust 104 20" Wheels
massivespl
I'm not mean, I'm honest.
Michigan
Look good. I had a set of chrome oem rims kinda like those years ago
massivespl
Michigan
My Burban is Tungsten Metallic and I thought these wheels would look good since they are gray with a silver lip. They are also clear coated which is good for Ohio winters. Let's see if I can get this picture link right. Dare I ask for the forum member's thoughts? Also curious what 20" tires any of you prefer?
http://www.tirerack.com/wheels/WheelCloseUpServlet?target=runWheelSearch&initialPartNumber=10428538AML&wheelMake=American Racing Authentic Hot Rod&wheelModel=AR104 Torq-Thrust ST&wheelFinish=Anthracite w/Mach Lip&showRear=no&autoMake=Chevrolet&autoModel=Suburban&autoYear=2016&autoModClar=LS#viewOnVehicle
I like Bridgestone dullers for my 20s never have any problems in the snow with mine. I took it out in 8 of snow last weekz
DP121
DP121
Thanks for the responses. I got a quote Friday for $1700 with Goodyear RSA tires. I don't like those tires. Gonna shop around some more.
undertaker
Long Island NY
try and get an actual weight rating out of american racing before you pull the trigger on those rims. I had 5 lug 18's on the tahoe limited and found out later on that the weight rating on the rim was only 1500 lbs each, on a truck that tipped the scales at 5850 lbs with the big block, 4l80, big rear and stereo system. That was before I put the 24 ft enclosed on the back. Not sure if you plan on using your truck for truck stuff.......but it might be a consideration.
if you read the description they're low pressure cast. The forged weld's on the suburban are something like 3800 lbs a rim. (ironically weld and american racing are part of the same parent company)
DP121
DP121
Yes I'm towing a boat thats 6300lbs with fuel & trailer. I have no idea how much weight all the other equipment adds to it.
DP121
DP121
According to American Racing's web site it appears that the load rating for these wheels is 2200.
Drewphil
