How do I connect this amp?
JesusArTorres
Tulsa, OK
I had this installed some years ago, but I removed it a couple of months ago. Now I want it back in, but don't know how to connect it. Some wires seem obvious but others don't.
Red = Batt +
Black (larger) = ground
Black (with blue) = remote
RCAs = obvious
2nd pic = no clue LOL. Shoulda labeled those.
***shoulda taken pics prior to taking it out*** :hands:
JesusArTorres
JesusArTorres
Tulsa, OK
Red = Batt +
RCAs = obvious
Awesome. Thanks a lot!
Do you know if something else has to be done first or connect one wire before the other?
YukonXL04
The Riverboat
Arlington, TX
Look under the hood for a fuse, remove the fuse. Then hook up the Red, black and Blue.
Hook up the RCA's then grab your speaker wire and see if it is marked with a line or symbols or something, and make sure you connect it the same way at the sub and at the amp. IE: wire with a line goes to positive speaker output on the amp, and the red terminal on the sub. the negative on the amp goes to the black terminal on the sub.
JesusArTorres
JesusArTorres
Tulsa, OK
Thanks for the info!
After some googling, do I pull "Radio 15A" or Radio/AMP 30A"?
I believe @YukonXL04 is referring to the fuse that is at the battery. When the amp was installed it should have been installed with an "amp kit". That red wire should be going from the amp to the battery with an inline fuse near where it connects to the battery. He's saying to remove that.
YukonXL04
The Riverboat
Arlington, TX
That's the one! You should have removed it when you removed the amp lol. Chances are it's blown though.
ezdaar
Chat Troll
Redneck central, Aka Houston
Thats it. pull that fuse.
Wow, fuse in while power wire is flopping around in vehicle next. possible fire.
Its not blown, I can clearly see the bar inside the body.
JesusArTorres
JesusArTorres
Tulsa, OK
The speaker wires don't have any label or white lines. They are identical. Do I just chance it and switch them if it didn't work the first time?
Fuse still looks good.
YukonXL04
The Riverboat
Arlington, TX
LOL. I saw the bar too, but they dont always break the bar when the pop.
As for the speaker wires, just hook them up however. Since they arent marked your just guessing. Once its all hooked up and working again, watch the sub when it hits and see if the cone is pushing out or pulling in when it hits. If it pushes out then your good, if it is pushing in then flip the speaker wires. It will technically work either way.
JesusArTorres
JesusArTorres
Tulsa, OK
I connected everything and it didn't work. I reversed the speaker wires and nothing. Went to a shop and the guy said it was the battery wire. $30.
Thanks for all of the info!
6point2lovelifers
