squeaking rear doors
benztrk
Central FL.
Ok, I have 2000 yukon that the rear doors squeak every time you open or close them. My brother and sister also have a 2003 and 2004 with the same issue. It seems to be squeaking on the top door seal. Does anyone have anything for stopping this? Please help......
FERGHOE
Hoe Owner
Grapevine
A few layers of armorall or tire shine should slick them right up. Stopped mine for now.
NJ04HOE
Paterson, NJ
I had the same problem and I used a spray silicone (I got from work) on the rubber and it works. I think the amor all and stuff like that dries out the rubber in time.
gtbigup01
Columbus, GA
+1 I had the same issue and I was spraying WD40 on the hinges but it won't go away, I was like WTF. A careful insp of the squeak i realized it was coming from the rubber seal rubbing on the edge of the door so I used my black magic detailer and put a light coat on the rubber seals all around my doors. No more squeaking :hands:
T3rry
Calgary, Alberta, Canada
i have the same issue, but i think mine is coming from the piece near the hinges that holds the door open.. i dumped like half a can of spray silicone lube in it, didn't help.
B
benztrk
Central FL.
Yep, got some silicon spray and lubed up the door rubbers....... ALL BETTER.....:)
ROBERTOcritser
Kentucky
I have the exact same problem. The corner of the door rubs the rubber and squeaks. Not really worried about it but if I happen to remember I might fix it.
yukonjacks
A Vegitative State
The Confluence
I got 3M silicone paste, part#08946, its for weather stripping rubber bushings, brake calipers and electrical connections. works like a charm
Durobans
