TheAutumnWind
- Joined
- Jan 8, 2015
- Posts
- 3,255
- Reaction score
- 1,997
Ok, so I had planned to replace the shocks sway bar bushings and end links and be done with this thing for awhile, but after getting underneath it and squirting all the zerks with grease last night I have pretty much determined that bushings and ball joints are probably all shot. Passenger side UCA ball joint boot is split, and basically everything had no grease.
Im sort of pre shopping here, as I have a big family move to do in the next couple of weeks, but I would like to greet the new neighbors by blowing apart my Denali in the driveway. Should be fun.
Can anyone comment on my shopping list here? Am I missing anything other than sway bar bushings? (have to determine what size that I have)
EDIT: also if you can suggest some low buck upgrades (Or savings somewhere) I'm certainly up to that within reason. Doing poly sway bar bushings and Monotube shocks for example. I plan to lift this a bit once I need new tires if that makes any difference.
Updated with control arm bushings
