2015 LTZ leveled w/ Denali rims
Getfooled
First time Chevy owner. 2015 LTZ With old style Denali rims. " leveled"
G
Getfooled
Yea I would like a bigger ratio, I may swap out for 20"
Jonah52
Senor ******
Cleveland
You gonna put bigger tires on? Or do you mean you might sell those wheels?
G
Getfooled
id like something like 305/55-22" tires but I think that's a 35" tire. Which will require a lift assume. Not digging the rubber and looks being its a 4x4. Bigger tire but I'm limited on 22" selection so rims would have to go also. Don't get me wrong I'm not a tire salesman so not sure what options I have until I stop by a tire shop and see what's out there.
Goodinblack
I Like Tacos
Dirty South
I am not digging the tire wheel set up.
Get 20s and a AT type tire
375s should be easy to sell
Jonah52
Senor ******
Cleveland
I could be interested in your current wheels and tires for the right price?
If you have questions about AT tires and 20's PM me
G
Getfooled
These size tires but as low of a lift as I can get away with, is the look I want. Not m/t tires tho.
Jonah52
Senor ******
Cleveland
Thats's gonna need 4'' lift minimum and lots of trimming, most likely 6'' to fit 35x12.50's
01Konvict
Boats n Hoes
Raleigh/SML
Those are 35x12.50" Toyo M/Ts on what appears to be a 20x9 +0mm offset on a 6" lift for sure! You could stuff a 305/55R20 on stock rims under a level kit but it will rub and need trimming. I would look in the 295/xx range to avoid all the trimming. If you like the look of that tire then get the Toyo R/Ts. They look almost the same but by far quieter and have a 45k warranty.
massivespl
I'm not mean, I'm honest.
Michigan
Put some 305/45/22 cooper zeon ltz all terrain on those 22s and it would look sick!
AdrienR
