New Owner
kylevd23
Hey Guys, didn't know if this was the right forum, but just wanted to introduce myself, from DFW, and this is my first GM product ever. I grew up driving toyotas and have had nissans since. I just recently traded in an Armada, and purchased an 08 Yukon Denali XL. We needed the extra room of the XL for our kids and strollers, seats, etc. Overall the vehicle was in excellent condition aesthetically, did find a few things like the power running board motor was making a weird noise, and possibly fan belt or tensioner noise. Yesterday did end up having it towed to the dealer, the radio started to reset itself, and door locks would cycle, and no acceleration, so they are going to look into this for me.
I do apologize, as this is the first time I have bought a vehicle, joined the forum, and started off my first post with issues haha. But none the less, both my wife and I love the vehicle, even for only owning it for less than a week :)
I guess the 6.2 L makes up for all the flaws haha.
Pockets
West Ga
Welcome aboard... glad your liking your new truck even with the few problems that's came up. I'm sure once you work through the little gremlins it will be fine. There is a wealth of info and very knowledgeable people on here. Ask away if you need anything....
GM Customer Service
Michigan
kylevd23,
Welcome to the forum and to GM! I apologize that your recent Yukon acquisition was met with having to get it towed to the dealer for various concerns. Please keep us posted on how your dealer visit turns out. We're here if you have any additional questions. Send over a message anytime!
Kind regards,
William R.
GM Customer Care
HoS
Welcome to the family.
Buying a used car isn't without the problems, IMO, most people don't sell a perfectly running vehicle. Don't put that on the truck, or the manufacturer.
K
kylevd23
kylevd23,
Kind regards,
William R.
GM Customer Care
Thanks everyone for the welcome, I most certainly will post up updates, and even after research, I have a pretty good idea on what it is. So far the dealership has been more than welcoming and helpful with the whole ordeal. I have received daily updates, and regardless of the issue, I am still happy with my purchase, just a little anxiety as we have not got to drive it yet since we bought it. They did give us a complementary rental, though its a buick, still nice. And I would definitely not put it on the truck or manufacturer as you are correct, all used and new vehicles will have its kinks and things to work out, just like us, we all have our quirks, which makes it all the better. But I do hope to get it back soon so that we can start enjoying it. Thank you for all of the support, I'll touch back when we the dealer lets us know.
Mr. Merk
My bet is on the battery cables. Probably in the $700 range.
K
kylevd23
So it was the battery cable that was causing the issues, they said it was loose, so they cleaned up the terminals, and tightened the connections. They found a bad motor mount as well, so that was replaced. The only thing they were not authorized to replace was the power running board motor, which I was okay with, everything else seems to be great.
Mr. Merk
That's good, at least it was something simple.
A lot of times the actual cables can develop internal high resistance and need to be replaced. There are three separate cables that are usually replaced and run throughout the engine bay. It can cause the issues you were having and also keep it from starting.
If your issues come back, try just touching the cables terminals with just your finger, if the issue stops immediately you'll know that's it (as crazy as it sounds.)
K
kylevd23
Yea, I may just replace the cables ahead of time as preventative measures. Should I just go with an OEM replacement, or are there better aftermarket ones available?
Mr. Merk
I only know of the OEM replacements. They aren't just regular cables, more of a harness.
justinesky
My escalade did the same thing with the radio and locks twice with in the first week i bought it. I changed the battery cables and added another battery and added/regrounded everything. Never had a problem sense.
K
kylevd23
Were the cables pretty easy to swap out? And when you added the additional ground cables, does that refer to the big three swap I've read about in other posts?
Dh1280
