Super Charger? Looks like a turbo....
NathanJax
Vacation Nathan
Jax, Fl
Vortec supercharger maybe?
Grocery Getter
Grocery Getter
A guy with a truck.
Phoenix, Az
How does a turbo work compared to a supercharger. I never had an import or a turbo diesel so I'm not too familiar with the workings of them. Does it just go inline from the filter to the TB and kick on at a certain RPM?
jomulk56
Resident Lurker
IN
It could be a centifugal supercharger, they look like turbo units. Vortech makes some like that.
road1will
pretty pretty good
Johns Creek, Georgia
Is this a serious question?
And whoever posted that ad doesn't know what they're talking about. Its listed for an 00-06 5.7.
dropmech
Puddle Pirate
Coral Springs
This. The difference between a turbo and sc is the turbo is driven by exhaust and a sc is belt driven off of your crank. A sc has more immediate response then a turbo because the turbo has to wait to get the results of the throttle inputs until after the combustion cycle has completed. There are two types of sc's, centrifugal and roots type. A centrifugal looks just like a turbo, but with a pulley on the outside of the housing to put an engine driven belt onto. Ask for more pictures to make sure that this is, indeed, a sc. I don't suggest buying this stuff without personally inspecting it though. You need to find out things like pulley wobble and shaft wobble.
Grocery Getter
Grocery Getter
A guy with a truck.
Phoenix, Az
Thnx for the info guys...... I wasn't too interested in picking it up I've just never seen a supercharger like that or heard of a Tahoe/Yukon with a turbo....
I take that back, that kid had that sick thread with the twin turbos on the Esky, right?
At any rate. No I know a little more about the different supercharges and turbos. Thnx guys. Peace out.
BOSS
The People's A D M I N
Dallas
Trust me, alot of guys just don't know what a turbo or supercharger is. I had a guy who is 100% into cars tell me the other day that superchargers work from exhaust. I had to politely send him a link a few days later and say, "Hey check out this new supercharger I'm checking out."
It was a pic of the supercharger and the air intake :)
BOSS
JKmotorsports
Austin, TX
... There are two types of sc's, centrifugal and roots type.... .
Actually, three types of s/c. Centrifugals, roots, and twin-screws. Roots and twin-screws are very similar in design, but operate slightly different on the inside on the way they draw and discharge the air. Twin screws don't produce as much heat as roots blowers do, but they rob slightly more power because it has internal compression ratio unlike the roots. Whipples are twin-screws, Magnachargers are roots style, and Paxton, ATI, Vortech are examples of centrifugals.
BTW, the pic shows a centrifugal s/c. You can see the gear drive housing on the backside of the unit towards the top left. The year is wrong, but judging by the intake tube, it's for a TBI motor.
Modded
That Guy
JK prob. just made some of you'll feel illiterate :shocked:
puckhead
CO
Any difference in performance?? Those centrifugals seem to be cheaper used than the roots/twin screw. Or i just haven't looked hard enough.
BlizzardX23
Sacramento, California
Its a supercharger I believe
Pro Charger is famous for that look...lemme dig up a pic
It'd be easier to tell if they had some better pictures though
Escalade with Pro Charger
And here are videos of the famous Pro Charged Denali destroying a few cars
http://www.youtube.com/results?search_query=justin87gn+denali&search_type=&aq=f
JKmotorsports
Austin, TX
Positive displacement units (twin screws and roots) provide all of its boost throughout most of the entire rpm range. Centrifugals build boost as rpms climb, so their off-idle/low rpm boost is usually very low.
Also, centrifugals need to be tapped into the engine's oil system to provide lubrication for the s/c. Roots and twin-screws don't. Whichever s/c is chosen, the fuel system needs to be upgraded and re-tuning is a must.
Rivieraracing
Sorry about the wrong info, I stand corrected!! I didn't notice the pulley when I saw the pic this morning!
Eagle
Thansk for all the help -STAFF!
EL PASO, TX
ehhh. a s/c does not necessarily have a more immediate response.
1: 'responsiveness' is a function of the turbine sizing and AR on a turbo. For a positive displacement s/c it is is a function of how quickly the electromechanical clutch engages, or the compressor bypass closes, while centrifugals even then don't make full boost until redline... blech. they have no response :)
A porperly sized turbo will give you full boost form immediately off idle to redline, something only a roots style blower can do. Unlike a roots style blower however, you are not locked into one boost level per pully size, nor low boost. it also won;t suck up 30-40 hp out of boost unlike a supercharger.
JasonW4141
