Broken rear window defog contact
tojo152
PA
Fixable?
08grey
I fixed mine the other day
I used a small butane torch soldering iron. You can buy a torch lighter at the gas station and it will do the same.
Grab it with a good plier at the tab. Heat up the underside with the mini torch. You will see it liquefy. Place it in place and hold. Wait a couple of seconds till it's solid. Now let go let it cool and grab it again. Apply the torch to the now backside you will feel it jostle slightly when it liquifys. This takes only seconds. Now all the solder on the glass has become liquid. Remove the flame hold your pliers and don't move it for at least 10-15 seconds. It should harden. Let it sit overnight don't reattach the wire yet. Take the coil wire and strech it some as to relieve some of the tension and the next day plop her back on. Should be good as new.
asx455
Rhode Island
It is a common problem and it is fixable. Locktite make a kit for under $10.00 and you can buy it online. Google search " rear defroster tab adhesive" and you will find it. It has great reviews compared to some others. I am ordering it myself.
3Dcaraudio
Defog contact repair
You can go over to Oriley's, they sell a repair kit that works just fine.
M3kanic
This happened on my 2010 tahoe. I took it to the dealer and it didn't even last a weak. So I did some research and found http://www.frostfighter.com/index.htm. It has lasted. Now it has happened to my 2002 suburban but I have not had time to fix it.
denalianyone
NYBlackLade08
New York
Permatex is cheaper n works. Frost fighter is a bit pricey.
Larryjb
Sorry if I'm bringing up an old thread, but I think THIS is the solution I was looking for, especially the weblink. Should this be in the tech info?
Anyway, thanks Nicholas, I'll probably be trying that fix.
Larry
CKendrick
