NCTyphoonKid
Clean
Wow those sure are bright lol. I got mine mounted up and wired into the trailer harness... they aren't working... gonna have to break out the meter and see why.
.All i remember is the ground isn't black and power isn't red lol. I tapped directly into the stock reverse wire for my positive, and drilled in 2 self taping screws into the bumper for the negatives. Good luck.
Okay... this is going to sound silly but mine just refuse to work... which wire from the led lights are you using as a positive? The red or black?
dimensions of the ones i got are 6 1/4" wide, 1 5/8" tall, and about 2" deep. Definitely smaller than the stock fogs.
Got them installed, and i'm pretty happy. They're 6000k, so they don't match the 5000k leds in my housings, but i think the brightness more than makes up for it. And i was skeptical about how it would look during the day, but i think they blend in pretty well.
Like i said, only thing that could make these better is if i could find a 5000k version. Anyone know where i could find some?
Its pretty easy to use the trailer harness wiring, just tap the positive to the purple wire(reverse wire) and the negative to the white wire. If you want to use the reverse from the taillight then take off the tail light assembly then grab the reverse light bulb and use the wire that is attached to it and splice a wire into that wire for power. For the ground(negative) wire find a bolt that you can ground it out at.
Fosscore your rides looking good. You should definitely color match the front grill i highly recommend it, it put a whole new look to my burb after years with chrome. Besides my exhaust tip, chromish headlights and lug nuts thats the only chrome i have on it now. As to your bumper lights are those amber or white when lit.
Washed it yesterday, put esky window, third brake light and vents on.
Jiggy-J
