RED '**---->my 02 build thread
bansil
East TN in the MNTS
Been lurking, gathering data
Have wanted a tahoe for years; cue: kids,college and now #&*% (FBHO)
I bought her, she is sexy "arrest me" red and 13 years old......now....now :Nonono:
She has 128K on her chassis and shows a few GM flakes of her clear.....wow...
And talk about stacked!!! :licklips:
She has 89 options (according to a vin search) and they all.....work!!......
I have folder full of quick mods I have saved up.....will do write ups and a build thread
Also she is 4wd, 3.73's and G80 which is nice and tight
Her she is at work yesterday :rockit:
Only Red one I found in my search, and the three tone interior is growing on me :Caffeine:
Her backside
First thing to do?
Grab my folder of saved mods to do
---------- Post added at 06:15 AM ---------- Previous post was at 05:58 AM ----------
First mod was the high pass wiring mod for stereo, not the neatest one
hardest part was "breaking loose" the amp from mount to move it for install of cable, it was "glued" with 2 sided tape???must of been a rattle at some point
Amazing difference in sound quality :party36:
so now the factory sub really sounded like shit!!
so....tear apart back of truck
find this:
and since I didnt have any silicone....I used Plumbers putty :jester:
installed
sounded good except for the rattle...who was the genius that designed this
:hmmm2:
I rolled up a rag and stuffed it behind the box and then grabbed a 1/2 in ling screw with washer.....no more rattle
next mod?
4 high mod
simple 5 min job
pop out light and splice into yellow wire and ground it out
walla'
So a nice 3hr date with my **' turned out great with all the pre planning done...next?
Speakers, since two sound bad, now that they have bass to them
YukonXL04
The Riverboat
Arlington, TX
Congrats on the purchase and welcome to the forum. Beware once the mods start they never end!
B
bansil
East TN in the MNTS
first step, remove dash bezel
then 7mm(socket size) bolts x 4
well, she decided to bite as I pulled on her gage cluster
I know "dont be a pansy" I am still on blood thinners so I had to stop the bleeding....3 bandaids later
pop off back black plastic
remove 6 larger light bulbs
grab a hand full of sockets and LED's
and replace them
remember to not over "tighten/turn them" because you will not make electrical contact
see the contacts?
see the contact strips on the board?
and notice the "groove" in the sockets, which is too long for our dashes?
so turn them enough to stay in the hole and have contact with board
repeat 6 times
put back together, before final assy make sure polarity is correct, you may have to spin bulb sockets 180*....i will find out tonite
next door lights, small screwdriver on the "RED" end will pop them out
the 5 LED bulbs dont fit into the sockets...so....
break out your step drill and open them up
open up to 1/2 inch
install bulb and repeat around the truck
next?
fire up grill, open a beer and precook meat for dinner:ehcapt:
Tahoewhat
Ballin' on a Budget
TX
This is a great build thread - pictures information and end result. Very nice.
Never heard of the wire high pass mod? - (never had stock radio either though)
B
bansil
East TN in the MNTS
Thanks ya'll
gotta check out my bus build
time for updates, just got back from the winery
dash...yup...red not blue...I have 100 more leds for everything else
so when we leave winery...we have nothing but dirt until we get home (5miles of road actually)
well......mama said "why does it smell like paint?"
ugh..ugh..oops...she rolled her eyes....
grills look alot better in person??? no streaks etc...weird
she actually said "you know your 45 and not a kid....:upyours:
oh and door lights
Blue2002Tahoe
Great build thread! Nice to see someone else paint the speaker grilles too, are you planning on painting more of the interior red or just the grilles?
B
bansil
East TN in the MNTS
thanks
more will get painted, like the inserts around door handles
need to pack bus, so projects may be delayed for a couple weeks
tgui
I have an 02 as well! I love the red.
Check your front diff fluid and magnet when you get a chance. I get the feeling that the front diffs eat bearings more often than not. I sure found a nasty surprise!!
B
bansil
East TN in the MNTS
need a small inverter to power my car-puter I am going to install, so I found time to turn this 15 yr old one into a "new" one
take apart and clean, sandblast outside
paint and bake
then I made new stickers for it
also started on my next project, I modified cup holder with some led's so I can see to put drink in
drilled 2 holes
inserted led's with resisters and leads
drop of super glue
and here we go
still need to hook up
tgui
Neat!
A carputer plus something like Arduino controlling relays and whatnot could be a ton of fun.
B
bansil
East TN in the MNTS
been busy with so many other things, did get to color match a small amp for subs
got drvside led swap done, I alos added an "aux power out" for future lighting
and some ambiance :jester:
not too bright, just nice glow (will see in the morning drive to work :party52:
next to finish up other doors and add "puddle leds " into bottoms of door panels
B
bansil
East TN in the MNTS
pulled out an old skool band pass box I had circa 1989 :wtf:
and cleaned it up, added led's and new subs and just had fun with it,
it may be too loud for my old ears now :jester:
I had some copper tubing laying around and used it as wire chases
and finally some sandblasting, black paint and some time with plotter a "brick wall with graffiti" (plastic was scratched up, so easy mod to hide finish, still glossy and clean on bottom side) I added red leds under the glass edges
once again wife asked how old I was :roflbow:
B
bansil
East TN in the MNTS
so this morning's job was to get rid of using the tape deck adapter and the static and noise from that
tin foil to protect board from oopsseess
done...next
I dint have anymore leds so...candy **** red nail polish :licklips:
it worked 30 years ago...we will see tonite
sounds great...and a this mornings breakfast picture :party52:
Blue2002Tahoe
Wow you've been busy. I'll be interested to see how your nail polish job looks
Hodmjstone
