need help.. catalytic converter
laprodigy001
hello,
i am trying to replace my cat.but every picture i see that says is a direct fit does not look like my setup.all pictures show 2 cats under the passenger side of the truck but my truck has a driver side and a passenger side cat.reason i am looking at cats is because i am getting code p0430.
can anyone help me figure out what cat i need?
1998 gmc yukon 4x4 slt 4 dr
BirchyBoy
If you follow the exhaust down from the engine, the OEM setup has both tubes going to the passenger side. Each tube has it's own cat. The tubes then go into a "Y" and then into a single muffler.
Does yours not look like this? If not, the previous owner may have altered the system.
laprodigy001
laprodigy001
this is my setup from the rear looking forward.i have a cat that sits under the driver seat and the passenger seat.but the pics of the replacements have both cats sitting under the passenger side
BirchyBoy
Mine is a stock '99 and does not have the cat to the left of the drive shaft like yours does. It's possible that there are different setups, though. Hopefully someone here will know for sure.
ccapehartusarmyINF.(ret)
Gilbert AZ
on my 2002 the cats are right after the headers
---------- Post added at 11:12 AM ---------- Previous post was at 11:11 AM ----------
when i had cats
---------- Post added at 11:13 AM ---------- Previous post was at 11:12 AM ----------
i hate cats the animal and the automotive kind they both serve no purpose
Jerky Arm Ape
North East Louisiana
Is that a 6" suspension lift?
Drivers side may have been re-routed due to the front drive shaft being lowered.
---------- Post added at 03:04 PM ---------- Previous post was at 03:01 PM ----------
What's the bracketry in the upper balljoint area?
laprodigy001
laprodigy001
so this does not seem like a stock catalytic converter setup?
Gilbert AZ
on most tahoes ive seen there is even an exhaust installation wright up and you can see the cats are right behind the headers i know this because they were hell to get off
---------- Post added at 02:24 PM ---------- Previous post was at 02:09 PM ----------
why are wehaving a discussion about replacing cats? do you have to do vehicle emissions?
if you dont get rid of them. get the o2 sensor simulators even if you do have to do emissions its OBD2 so all they do is plug into the OBD2 port and test your gas cap at least in arizona thats all they did to mine and no it has not affected my gas mileage in the slightest
laprodigy001
laprodigy001
i live in nj and i only have emission inspection.but i am getting a engine code p0430.if i get a o2 simulator will that take the code away?how do they work and is there a brand i should get.will i pass inspection with them in?
thanks
SunlitComet
OBS Jedi-Do Good
unknown at this time.
that setup might be a california converter setup that i think was implemented i think starting in 1998. i saw the same thing in the 2000 limited 2wd units. assuming nothing changed in the area where the original setup went then the old style should fit. there might be concerns tho with the o2 locations that might be slightly different and may need longer or shorter wiring. you likely would not get dinged either by a smog shop because is will look like a factory mounting position.
laprodigy001
laprodigy001
i live in NJ but when i checked the carfax i believe it was purchased in Cali and registered there for the first few years.
if i am throwing code p0430 could that be for anything else besides a bad catalytic converter?
TheSwede
Sweden
On My 2000 yukon xl 5,3 4 WD i have similar as you. My is imported from us Florida i think. And i have seen "cats" that fit mine on ebay.
TheSwede
Sweden
On My obd scanner i can see o2 sensors and do a diagnostic on them to see wich is bad, dont know if it works for you. I bought a scanner on ebay and it seams to work quiet good.
Drewphil
