Guys it's been awhile since I have done some mods because I am still working on my retro....
Anyways I bought an E-Prance dash cam and installed it tonight. It was exactly what I was looking for and not that bad of a price. I had witnessed a few things recently that I wish I had caught on camera so I went for it. I also purchased a fuse tap to usb mini power harness, at $40 it seems expensive but I'm OCD and it makes the install very easy and clean. Anyways onto the install.
Here's the camera:
http://www.amazon.com/Miniature-Sin...&qid=1404184294&sr=8-1&keywords=e-prance+0801
USB Power Harness:
http://thedashcamstore.com/dashcam-installation-kit-5-volt-usb-plug-mini-fuse/
Memory Card:
http://www.amazon.com/gp/product/B007XZM6VG/ref=oh_aui_detailpage_o07_s00?ie=UTF8&psc=1
First thing, setup the wiring to make sure everything works.
I used the driver side fuse box:
Find a hot start only fuse, there is only one in this fuse box and its a 2 amp fuse. Got lucky cause the camera only needs 2 amps however the fuse tap can use any amperage.
Then setup your ground, plenty near by:
Now stop and test the camera. Everything worked fine hot start only charging and stops charging once the key is off and driver door is opened. Exact setup I wanted.
Next run the wires, really easy to do:
Remove the A Pillar cover
Pull back headliner and tuck, it's not coming out if you pull the headliner back far enough, but be careful
Mount the camera in a location that you can't see it from the driver seat so it won't distract you. Also where it's not obvious it may seem that its quite visible but because of the tinted windsheild up top and oem sun shading in the middle this is the only location I could mount it. I think it blends in well.
Now run and test the camera, based off my settings it auto records 3 min videos once it receives power aka the reason for the hot start fuse. It will record up to 32gb and then will overwrite and delete the oldest file and so on.
Then clean up the wiring and close up the fuse panel:
Let me know what you guys think. Overall I spent about $150 but it could save me much more if I ever needed it in the future or it could help someone else.
EDIT:
Here is some footage of it installed
[yt]PTj2sHtpS9o[/yt]
Anyways I bought an E-Prance dash cam and installed it tonight. It was exactly what I was looking for and not that bad of a price. I had witnessed a few things recently that I wish I had caught on camera so I went for it. I also purchased a fuse tap to usb mini power harness, at $40 it seems expensive but I'm OCD and it makes the install very easy and clean. Anyways onto the install.Here's the camera:
USB Power Harness:
Memory Card:
EDIT:
