Spindles or Struts
g35kid
So Cal
Hey guys looking for help lowering my truck. I really wanted to go with the 3-5 drop but the ONLY thing preventing me from doing that is all the work that needs to be done to prevent most of the rubbing.
So right now my truck is on 26" rims and looking to do the 2/3-4 drop and been reading the some are getting the front lowered by using lowering spindals and others are doing it with the lowering struts. Is there a benefit one way or the other. Any input would be great
IF you guys think im being a big baby because of the work that needs to be done on the 3/5 drop PLEASE let me know cuz thats what i really wanted to do. if there is any write ups on that matter i would like to look at it...
Thank again guys
NORCAL SS
SUV SUSPENSION GURU
Thank again guys
how many miles are on the truck?
also what size 26s? 305 30 26?
MrSnacks
Mesa, AZ
What is the offset on the wheels? I have a 3/5 drop (almost 6 in the rear) with both the spindle and adjustable struts on 26's on 295/30/26 and I have very little rubbing. Most of the rubbing will be eliminated by trimming the plastic where the wheels rub.
g35kid
g35kid
So Cal
Im glad someone chimed in about going lower !! Not sure what offset the rims are though . Is there a way i can find out? Im running the same rims a few others r running on this forum which are gianelles if that helps at all.. mr snacks would u mind sharing what set up ur running thanks
Yoey
Need a lil help...
So I just bought a 2008 Yukon Denali. Did the Bilstein Spindle Drop on it 3/5 and put some white 24's on it. It has the air ride suspension, which i bought because I planned on lowering it. But, its bumpy...real bumpy. I want to know what you guys think I should do to fix this issue. Ive thought about switching over to the coilover system? also thought about lowering it using a shock system and doing the 2/3. Any input would be great!
NORCAL SS
SUV SUSPENSION GURU
Bilstein never sold spindles to lower it. My custom 3/5 kit on autoride rides nice.
So what all parts did you use?
Yoey
So I did a little research. I believe the guy who did my install used the bell tech 2509 2" drop spindle kit for a 2007 Chevy Pickup, Tahoe, Suburban, Avalanche (2509). And he used the 23323 Belltech "Pro" Coil Kit. Though he did not use the shocks that came with it. I am guessing he customized this somehow, because I read over the "Pro" Coil Kit and it states that it is not designed to be installed on vehicles equipped with "auto ride"
NORCAL SS
SUV SUSPENSION GURU
you have a deanli so you should have autoride. that being said the rear should have extenders and that is the wrong kit thats on the truck.
does the rear have shock extenders? the rear should use the 5305 rear set up coils with shock extenders and shorter bumpstops.
Can you do me a favor? on the drivers side can you see how much space you have before the bumpstop hits the axle and also if it does have the extenders. Are you trying to get the rear lower or just ride better?
Yoey
I am just trying to get a smoother ride...right now I can feel every bump and the front end shakes with every bump. The autoride with factory rims spoiled me. I wouldn't mind going lower but I still want to maintain my ride quality. I'll check the truck in the morning and let ya know what's on it. I believe he put different bump stops because in the parts returned to me there's some in there.
NORCAL SS
SUV SUSPENSION GURU
well in rear you need to change teh kit out the 5305 coils ride better made for autoride.
In front spindles dont change ride quality but in rear that kit just needs to be swapped and do the endlinks/new bumpstops on axle for free travel mod and you will be done and riding nice. the kit is 360 shipped for the rear but yah get some pics of the rear set up we can see whats going on.
Drewphil
