headlight swap
P Dub
El Paso, Texas
new to the forums and i searched couldnt really find what i was looking for. what headlights are interchangeable with an 03 tahoe that have the oem projector?
YukonXL04
The Riverboat
Arlington, TX
Im fairly certain no nbs tahoes or suburbans came with OEM projectors. As far as I know only the denali did.
Justinj360
Senior Member
Welcome to the forum! If you're talking about the Denali projector headlights those won't work on a Chevy. They're slightly taller than a Chevy headlight.
Z-56 Hoe
What do I do????
Houston
No NBS / GMT800's came with a OEM projector. Except the Denali which won't fit!
Z-56 Hoe
What do I do????
Houston
Does the above apply to a Yukon too?
The Yukon and the Denali have different grills and headlights and marker lights and bumpers!
You can however swap all that stuff over and you will be able to!
That being said there are aftermarket ones out there and you can get some DEPO projectors and retrofit them!
P
P Dub
El Paso, Texas
not a big fan of the depos i had them for my car and the output wasnt to good IMO
These are the ones i want to get that are retro fitted by someone i know
Shoreracer92
So Denali h/l won't fit in stocker yukon locations? Have to swap over grill and everything?
mharders
Just outside of Seattle
Denali lights are a straight swap with the Yukon and vise versa. No need to change anything else. Also Denali lights are super easy to do a retro fit into. Just did mine last month and took about an hour at most.
Sent from my SAMSUNG-SM-N900A using Tapatalk
WITCH1975
