Extra battery or Replace Battery (need help)
tahoe02
i turned down the gain and now it doesnt dim the lights that much but still a lil bit when i turn the sw up
rigo_jones
going against
DENVER mexico
:worship: Eagle u the man. thanks for the info, im probably going with a bigger alternator. big ending with the GI Joe video lol.
ROBERTOcritser
ROBERTOcritser
Kentucky
so your sayin my amp is bad, maybe? also I still havent found out what the Big 3 upgrade is....
Eagle
Thansk for all the help -STAFF!
EL PASO, TX
well , ican;t say brother. that is the problem. I can point out some checks for you to do, and If it were here, I could figure it out in about 20 minutes.
I don't even know what amp you have to state, 'yeah, that one has insufficient capacitance' or what size wiring you have used (hopefully 2ga or 0 ga.)
big 3:
upgrading the wire from the alternator to the battery, battery to ground and engine block to ground. (note that he second one isn;t even IN the amp's electron flow path).
Young28
The Yukon God
ga
he has a jl 1000 1 v1. stated in his first post. IIRC the 1000 / 1 only does 4 ga wire
btw you are full of good info.
Eagle
EL PASO, TX
ok, here is a question then, & sorry for missing that key info previously. the slash series are current hungry mothers... always have been.
If you have 2 0hm subs, or DVC 4 ohm subs it might be wired to a 1 ohm load instead of 4 ohm. That would CERTAINLY cause an increase in current consumption as it would be very very inefficient.
like wise if it were wired to 8 ohms instead of 2 ohms, you;d be running excessive gain to make up for the <correct> lack of output.
What is the impedence being presented to the amp?
8 ohm? 6 ohm? 4ohm? 3ohm? 2 ohm? 1ohm? 0.5 ohm (DMM across the two wires while NOT connected to the amp)
remember the 1000 1 is only 1.5 ohm stable at best (and 4 ohm is far better, while 2 ohm is also just fine). The RIPS technology means they are current hungry mother-funkers...
That is the price you pay for not having to worry (as much) about impedance matching.
Eagle
EL PASO, TX
NO problem...
are you sure you have "REAL" 4 ga and not 6 ga in a 4ga sheath? There is a LOT of that going around?
Single 12w7? or two? Single you should be fine...
ROBERTOcritser
ROBERTOcritser
Kentucky
single W7 it should be wired straight from the factory which I think is either 1.5 ohms or 3 but Im really not sure what ohm load its at right now but Ill try to find out for sure. and it should be true 4ga. I really cant be sure myself but Im very close to getting 0ga wiring kit. I know the 1000/1 only takes 4ga but thats something else I wanted to ask you about.... the car audio store Ive been talkin to says you can make 0ga go down to 4ga.... its a big Memphis 0ga wiring kit with all kinds of stuff (17ft 0awg wire, RCA's and some weird blocks... they said they were I think distribution blocks and something that makes 0awg funnel down to 4awg and some other weird blocks) I guess it is possible to use 0awg wire on a 4awg hole isnt it?
BTW I kinda wish I did have 2 W7's haha but that would be pretty overkill. I'm really trying to get this straightened out so I can put another amp in there for my high's and I really dont wanna run door speakers that dont require an amp cuz I think they will get better sound. Plus Ive already bought a pair JL C2 6.5's to go up front. I just wanna get this figured out before I start puttin more of a load on my system.
lastly, I kinda plan on having pretty much everything JL cuz from what Ive experienced, I think they have great products, even if it is pricey. I feel I can trust whatever else they make. (If they made a deck, Id prolly end up getting it haha)
Eagle
EL PASO, TX
sometimes... there are 0 -> 4 ga adapters.
however generally they are too big to fit one next to the other, so you'd need to keep a 4 ga ground (not a real problem since ground is probably only 12-18 inches.)
you might try upgrading the alternator to battery to 4ga first... can't hurt, and it would sure cost less.
if your plans involve adding another amp, then a 1/0 gauge kit is a good investment.
ROBERTOcritser
ROBERTOcritser
Kentucky
I actually got a piece of 8ga wire to add on top of the wire for the alternator to battery... would that be ok or should I just go straight to 4ga?
about the 1/0 kit, thats all I needed to hear... I might buy one this week.
fatnlowtahoe504
New Orleans, LA / Hattiesburg, MS
yea thos 1000.1s pull alot of juice, i had one at first with just the factory battery it dimmed like a mother, but i added a yellow top and capacitor and it solved the problem, now im running a kicker 1500.1 and it doesnt make it dim nearly as much as the JL
ROBERTOcritser
ROBERTOcritser
Kentucky
I just checked my sub with a meter and from what I can tell, Im fairly certain its at 1.5 ohms. the meter I was using wasnt a big yellow one like most people have and isnt extremely precise but it only flickered between 1 and 2 ohms so I would guess its at 1.5
Eagle
EL PASO, TX
I figured it was a DVC 3 ohm parallel.
Add that 8 ga. to the alternator & see how it goes. 8ga + OEM wiring should be more than ample.
ROBERTOcritser
ROBERTOcritser
Kentucky
the JL site says its Nominal Impedance is 3 ohm. Here is a chart copied from there site.
Free Air Resonance (Fs): 27.2 Hz
Electrical “Q” (Qes): 0.514
Mechanical “Q” (Qms): 7.807
Total Speaker “Q” (Qts): 0.482
Equivalent Compliance (Vas): 2.33 cu. ft. / 66.0 liters
One-Way, Linear Excursion (Xmax)*: 1.15 in. / 29 mm
Reference Efficiency (no): 0.249%
Efficiency (1W/1m)**: 86.2 dB SPL
Effective Piston Area (Sd): 84 sq. in. / 0.0542 sq. m.
DC Resistance (Re): 2.47 ohm
Nominal Impedance (Znom): 3 ohm
Thermal Power Handling (Pt): 1000W
Driver Displacement: 0.14 cu. ft. / 4.0 liters
Net Weight: 45 lbs. / 20.4 kg
ROBERTOcritser
ROBERTOcritser
Kentucky
ok. well I just put that 8awg wire between my alt. and battery and Ive noticed pretty good difference in how much less voltage drop Im getting.Right now I have
1.extra 8awg between alt and battery (small red box)
2.a 4awg wire ran from my battery ground to a random body ground nearby
3.and my amp's 4awg wired straight to the red box
number 2 might sound a little off but Im pretty sure it helped even if only a lil bit.
with all of this, Ive noticed a not huge but a very good difference compared to how it was before any of that extra wiring. Definitely dont feel like I need a big battery like the one they wanted to sell me. but Im not sure what to do yet b/c I still gotta put the other amp in there with my high's and see how much that draws from everything.
Eagle
EL PASO, TX
luckily, 'highs' jsut dont require the same brute amount of power.
johnsonwillie199
