Got the CCM Level Kit installed
CleanSweep
Virginia
I got the kit installed last night. Seems like it sits a lot higher than I expected. Glad I didn't go with the 3.5 Rough Country Lift.
Mods:
CCM 2.5/1" leveling kit.
Bilstein 5100's on all corners.
Moog Z71 replacement springs on all corners.
Nitto Trail Grappler 295/55r20 tires
I did Bilsteins because of the good reviews here and I needed to replace the smoothride suspension in order to lift.
I'll try to get better pics later after I clean it.
You can see the trimming I had done to it in this pic.
NathanJax
Vacation Nathan
Jax, Fl
Nice!!!
Neil Layne
Steel Neil
Lafayette, Louisiana
i have the nfab bars and a 2.25/1.5" lift with 295/55/20 trail grapplers just like yours and i did not have to touch them. how expensive did those shocks cost you? I'm thinking about doing that soon, it looks like it sits higher than mine. it looks great. if you were thinking about those running boards i would recommend them, i love them a lot.
C
CleanSweep
Virginia
The reason I had to do any trimming was because of the -12 offset of my wheels. Do you have a pic of how far the nerf bars come to the wheel well in the front?
Shocks were $363 for all 4 from Shock Warehouse but beware, they might not have anything in stock and might make you wait forever. I got lucky only had to wait a few weeks. The Moog springs were around 140 for all give or take a few bucks. How high is the center of your fenders off the ground? The reason mine may look higher than yours could be because of the Z71 springs.
Zed 71
Pacific NW
Yes, I had to trim them even to the metal. I'm thinking of getting some Nfab nerf bars but, I'm not sure how close to the wheel well they get.
FYI you might have been able to avoid that by adjusting the caster.
C
CleanSweep
Virginia
That's not that much of a difference. I'm not sure an inch and a half in the front is that noticeable. I would be curious to see the measurement if you put new shocks on.
awesomesauce0528
Arkansas
I noticed that you said you had Moog Z71 springs on all corners and I was wondering where you found front Moog springs because I'm only able to find rear Moog springs
Vigh_J
AB, Canada
That looks awesome. Leveling kit is on the agenda for my 08 as well. Thanks for sharing.
HeavyHoe03
