Some Error codes!
BIG-MAN
First of my name is Rolando I go by Big Man! I own a 2000 Yukon 1500XL 4WD
It's been a couple of days that i've been a member to this forum, i haven't posted anything yet since i've been searching the forum and have found some great info and help.
I have come across some codes in my Kon
P0305
I've changed the sparkplug, spark wires, coil #5 and did a Full FuelInjector service, code keeps coming up!! My next step is to find a way to check the injector without having to order an injector noid light. I saw some DIY stuff i would want to try to see if the injector is firing correctly. Also i saw some on ebay and would like to know if anyone of you have tried them or have heard anything on them?
P0440
Looks i will order a fuel cap and see where it goes from there
P0449
still searching on this code i kind of think it might be a Faulty purge but will see what happens
this is the thread i was reading and im having similar problems but mine is with Cylinder #5.
NathanJax
Vacation Nathan
Administrator
Jax, Fl
This thread belongs in the "Engine & Drivetrain" section because it's to "Discuss engine and drivetrain items from brakes, transmissions, towing, error codes, anything in the engine bay and so on here."
the " General Discussion" is to "Discuss anything else that doesn't fit in to one of the other categories about the 2000-2006 models here."
B
BIG-MAN
i actually did posted it there lol sorry amigo i got mixed up. there is another thread that is blank can you please delete it thankas
Jons2005tahoe
Have ran a compression and cylinder leak down test. Also your problem could be caused by leaking intake gaskets.
B
BIG-MAN
I haven't donee a test, im going to do some research on how to do one. Also I've noticed a strong odor of gas around the and sometimes inside the kon.
Timnazium
