Help on how to color match
LOWHOE775
Sparks,Nevada
Ok so I want to color match the grill except the chrome, side farings (wheel wells) top bumper cap. Any ideas on how to prep the areas so paint can stick. And what kind of paint to use. I want to do it myself save me a few bucks. Any ideas or help would be great
jomulk56
Resident Lurker
IN
Sand, grease & oil remover/acetone, adhesion promoter, paint, and clear. That's how I've always done it.
Z-56 Hoe
What do I do????
Houston
what he said and good luck make sure it's all smooth.
painter13
Hey! I'm a painter by trade, and what I always do, since these parts have texture. I scuff use a d/a sander and some 180 grit paper and buzz as much of the texture away then I spray a few (3) wet coats of some 2k primer. After the primer has cured, about 6 hrs. I sand it down with some 600 grit wet paper and then paint. This sounds like a lot of work, and it is! But if you want the parts to be as smooth as the rest of your truck, that's just what you have to do... if it was easy, everybody would be doing it.
LOWHOE775
LOWHOE775
Sparks,Nevada
Got the emblem and finished the grille.
---------- Post added at 12:20 PM ---------- Previous post was at 12:20 PM ----------
felixgun
Lafayette, LA
Looks good but question: why the unpainted black parts on the front and the fenders? Color match all of it!!
Grimes
Is this a difficult thing to do? What did you do about the paint that was already there? Just sand until its gone, or sand "enough"?
Looks great by the way. True quality.
TejasPitt
