flip kits
clean454
anyone ever install rear axle flip kits? and notch im getting ready to install one and just curious if anyone has some good pointers.. thanks
3-lot
Lloydminster, Saskatchewan, Canada
what kit you going with?
only real advice is measure, check once, twice, and again before you cut anything.
if your doing bell tech, they're kits are quite simple and the template for cutting and installing the notch brackets is pretty straight forward.
the flip itself is easy, pending parts come apart easy. just follow directions and double check everything as you go.
---------- Post added at 08:30 PM ---------- Previous post was at 08:28 PM ----------
trust me, this is a way easier job then the custom fabbed air ride i did last with a non pre fabbed 10" super c notch.
C
clean454
i was gunna go with djm but im hearing alot of bad stuff about them,
so prolly bell tech i just wanted to get some opinions, thanks
NORCAL SS
SUV SUSPENSION GURU
ive never had issues with either kit and sold quite a few on this site and others allready.
Lifted99Yukon
Kansas City, Missouri
Very easy install. I like DJM products, I have had both DJM and Beltech on my truck. Both great companys.
Flip Kit, just removed the whole leaf pack, super easy. Measure many many times. Make sure it's center with the axle. Just simple instructions to follow. You will be fine!
Post pictures when done.
Jumpshot12
