found New keys!! MAXX Cam 2 Leveling Kits
saif najd
Found this!
1998 CHEVROLET TAHOE Suspension MAXX Cam 2 Leveling Kits SMX-MC2
What is the story??
This what the site info:
Brand:Suspension Maxx
Manufacturer's Part Number:SMX-MC2
Part Type:Suspension Lift Kits
Product Line:Suspension MAXX Cam 2 Leveling Kits
Summit Racing Part Number:SPX-SMX-MC2
Primary Front Lift Component:Torsion bar key
Front Shocks/Struts Included:No
Rear Shocks/Struts Included:No
Brake Lines Included:No
Hardware Included:No
Quantity:Sold as a pair.
In-Store Pickup:Choose In-store pick-up (OH, GA, NV) on our web site.
Tired of that low front-end look? Need more ground clearance? Got a 4x4 and it looks like a 2WD? Then you need one of these Suspension MAXX Cam 2 leveling kits. MAXX Cams, Suspension MAXX's patent-pending adjustable torsion bar levers, add suspension travel and level the front. MAXX Cams are innovative 2-piece adjustable torsion bar suspension levers which, when calibrated, can compensate for torsion bar fatigue, allowing you to choose the profile needed to level the front with the rear.
The price -- $224.96 -- wow
_Dylan_
STAY FROSTY
waste of money IMO
just crank up the factory keys for free and get the same results
saif najd
saif najd
Ok, well try I am thinking of 1 inch front only because the rear leafs are noisy and I need to add something between them wich well rise the rear so I need to level it right
Sent from my GT-I9505 using Tapatalk 2
dhg4dragon8
Rison, AR
not worth 224.96.
but i would be care full about over doing factory keys. one hard bump and boom. buying a new set of torsion bars
saif najd
saif najd
I have those keys. See signature for result
Wow so you are the one who have the coolest 2dr around nice!
I see you added few things too so why you chosen this keys over crank?
Sent from my GT-I9505G using Tapatalk
bowtiefreak
No Quarter
Near Philly
sorry, my sense of humor is a bit dry.
I have stock keys in both my trucks. I use Rough country to lift my suburban and Cepek on the Tahoe.
My factory keys, as many people will be happy to inform you will (typically unless the bars are shot) allow you to crank to level and well beyond. however this will add a ton of stress to the front end.
Best advice for a 2" lift is a body lift or crank those stock keys and see where it gets you
saif najd
saif najd
It's fine non taken,
Hmm I didn't like the body lift to be honest but i am afraid of the stress on the front ends and at the same time with sand I really need the lift especially when I am offroading with the FJ group!! (Most of them already 3inch higher than stock) and I can see how I have the advantage of the torque (the V8 vs the V6) but I keep getting stuck!!! I need more clearance,
Again thanks for the help
saif najd
saif najd
rleary360
for $15 you buy the red ford keys.....ya get up to 3" of lift and keeps factory tention on suspension so ride quality dont change!
Sent from my Z750C using Tapatalk
rleary360
not sure about part# but i watched a few vids on youtube about tahoe owners using them
bowtiefreak
No Quarter
Near Philly
Please do some homework before believing a statement that a new key can yield 3" of lift without an adverse effect. Seriously, this is the most talked about topic with IFS trucks. Crank 3" and tell me how that truck rides.....and how the front end does in the long run...or even short term.
If I could get 3" from keys without issue, everyone would do it.
saif najd
saif najd
Hmm OK, tell us what is the problem? And how or what is the best approach?
I think 2" is more than good and should not cause any harm,
But!!!!
How and what is the best way or kit to get the 2" extra night without cutting or expensive kits?
SunlitComet
OBS Jedi-Do Good
unknown at this time.
2 inches of cranking is not really bad but does make for a stiffer ride and may wear out the half shafts sooner. going beyond that is just wrong tho.
saif najd
saif najd
Good to know, but we need a way around the stiffer ride!
I think cranking and upper longer arm would help to solve it right? Or do we need keys too?
I think I just got the concept of this front suspension system
briannorris
