Carbon Fiber vinyl wrapped interior trim
Sinister1
Dallas
Very nice looking. If you don't mind my asking, how did you lay the skin? Did you simply remove the parts, lay it on the skin and trace around it, and re-install the part, or did you hold the skin up to the part and trace around it while the part is still in place? If the latter, that seems like a cumbersome process. Regardless of your process, the finished look did turn out very nice! Something I may have to consider in the near future.
Shimmy23
WA
Is there a DIYer for removing the trim pieces? I've done this in a couple other cars, just wondering how easy its gonna be in a tahoe.
NathanJax
Vacation Nathan
Jax, Fl
nope. just pull :uhoh2:
Shimmy23
WA
I'm about to do this finally... GM is retarded for connecting the vents to the wood trim.
startingfromstock
I got around to wrapping my interior this last week... Looks much better.
Now, do I completely get rid of chrome for all black?
Pockets
West Ga
Looks good...[emoji106]
Sent from my V10 using Tapacrap
Sarge
South Alabama
How are yall installing it? Lay it on, cut with a razor blade? Heatgun? Solution spray etc
AppocAlexx
Darth Appocalexx
Abilene TX
I got around to wrapping my interior this last week... Looks much better. View attachment 58218View attachment 58219
Now, do I completely get rid of chrome for all black?View attachment 58220
Get rid of chrome, no one likes it, lol I"m jk I don't like it. I'm debating on doing as well. I have the same set up as you and I'm pretty sure that its the aftermarket sticky on chrome for me. Looks like you have the same stuff. I'm just hesitant on doing bc the plastic underneath can be tarnished and ruined from anything that may have been sitting there for how ever long the chrome has been on as well as getting the two sided tape of is hard enough as it is that being on plastic is even worse bc you can not use the same type of ways getting off the tape and glue as you can on metal or painted surfaces. The two sided tape can even ruin the plastic all together. If it does mess up the plastic you can always repaint with factory type rattle cans that make the plastic look new. If I do remove them it will be this summer when its a little warmer out side. Heat always makes things like this go faster when removing two sided tape.
Your interior looks good by the way. Especially like the steering wheel. I was looking at painting all the same parts as you covered and after seeing what you have done I may just wrap in black vinyl or another color. Even tho I'm no big into carbon fiber look this looks pretty good.
AppocAlexx
Darth Appocalexx
Abilene TX
Wrapping vinyl is pretty easy but take patience and time to do it right. Unless you do on the regular you may even do one piece 2 or 3 times before you get it right.
Using vinyl with heat gun or iv even used a blow dryer just takes a little longer, razors and a blunt tip type tool (w/e you can find just something that is not going to scratch the vinyl or tear it) to roll the edges and push into crevasses.
Doing this in a controlled or warmer area is also better but you always want to heat up the surface some just to make the glue stick better to the plastic or w/e surface you are applying it to. Also make sure you clean the surface good, soap that does not leave hazes and water works good. Not too much soap just enough to clean the surface and then dry it thoroughly. Make sure to cut enough to work with. Laying the wrap on the surface and then using heat to warm up the vinyl will make it wrap around the edges and turns/bends of the piece you are working with. Using the blunt tip tool to roll over edges or tuck into crevasses. Doing the heat and rolling/pulling/stretching you want to take your time on this and make sure you don't tear or stress the vinyl too much and make sure to keep it warm. If you make it too hot it will warp or bubble or burn and make holes then you have to start all over again. After you get all the stretching and w/e else needed to be done make good strait cuts. Rolling all excess under the piece as best as possible or tucking it under the places you can get to roll under after cutting. Cutting is probably the time that I pay close attention to bc you can get it perfect on there and looking good and cut it to short or too much and have start all over.
In all like I said take your time on it and depending on how picky you are will dictate how good it looks in the end. For your first time I would buy extra vinyl just to make sure you have enough in case you mess up a couple time or so, especially for bigger pieces.
I'm sure there are tip and tricks other people can add to what I said, this is basically how I have done this in the past with interior and exterior parts.
brice715
